Results 1 to 12 of 12
Thread: Drivers side boot leak.
    _Mukas_'s Avatar
    _Mukas_ is offline DJ Titan...Hardstyle guru
    VR 5.0L Statesman
    May 2006
    Edithvale born n bred...
    Unhappy Drivers side boot leak.
    this was kinda covered in another thread but i havent seen a definitive answer yet. i have noticed of late, apart from the wet towel smell, that the drivers side of my boot is collecting water, and i lost a cricket bat (worth more than my ###in headunit), shoes and gloves from the mould it provided!
    people mentioned screws n that were loose and to pull up the carpet n test it with a hose which i have done, yet i still cant find the problem. any help would be good.
    Thanks,
    Luke
    Loudness - the intensity of sound!
    www.globalhardstyle.com
    check it...
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    Good luck finding out. I searched high and low in mine. Suspected the fuel flap hinge at one stage as I could hear the water dripping in but could not see it when i was inside the boot. In the end I didn't have much time to keep on looking and I drilled a few holes in the bottom before selling it after I bought the ute.
    Commodore, VT S 97
    Jul 2005
    Queensland
    Had same problem in my 96 VS Exec, rear quarter window seal is probaby RS. Takes about 45mins to hour to do both sides, with minimal mechanical knowledge, a few spanners and a tube of window or body sealer.
    1. Remove seat belt bolt in trim inside quarter window
    2. Prise the trim panel off inside car behind quarter window.
    3. Locate bolts (platic type) in quarter window and remove. BECAREFUL, window will fall onto driveway if your not careful, have afriend or if you trust her, your missus to hold it.
    4. Clean old crap off, squirt on sealer and refix in reverse to taking off.
    5. DON'T OVER TIGHTEN BOLTS.
    Hope this helps.
    VZ SS THUNDER
    Apr 2006
    Yep had the same problem in a VP A few years ago... Was a complete bitch to find... As Greg_sian said was rear quarter windows.
    VS Acclaim
    Mar 2004
    Melb.
    I couldn't be stuffed taking them out when mine were letting water in, so i just got some black silastic and squirted it out from the tube, down the outside of the windows, where the water was probably getting in. Now the water run-off from the roof just travels along the silastic, and down the side of the car.
    Did it about a year ago, and it's still fine. And unless you go looking, you can't even see that i've done it.
    Forgive me if I don't reply to a query straight away. The E-mail notification function only works 50% of the time for me.
    _Mukas_'s Avatar
    VR 5.0L Statesman
    May 2006
    Well thanks for the info guys, i got the day off work today so i may well get into it shortly.
    Luke
    check it...
    BassTeQ Guest
    Had the same problem a few years ago, crawl in the boot with a torch, get someone to hose water on your window and watch where it leasks in!
    VS Acclaim S2
    Nov 2005
    has anyone else ever experienced a water build up in the little 'well' the spare tire stands in on the left hand side of the boot? you know how the little arch dip that the spare sits in is lower than the rest of the boot...? When i pulled out my spare once i noticed a whole load of water had built up in there and my spare was sitting in a bit of a slosh. I haven't noticed my boot floor being wet, just down in there. Main thing i don't want to have happen is have it get so high it reaches the boot floor level and gets water in to my amplifiers which are at floor level underneath my false floor.
    Commodore, VT S 97
    Jul 2005
    Queensland
    I had same problem, both sides leaked, once i re sealed qtr windows it was as water tight as a fishes bum.
    VS Berlina
    Jun 2006
    Lysterfield
    I have a boot leek, but I can’t understand how it is the quarter windows causing it. All the water is on inside of the boot roof, and when I open it water runs out of the most outer holes either side to the boot latch.
    Will resealing the quarter windows fix this problem?
    Thanks in advanced.
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    Do you have a spoiler? Could be leaking through the bolt holes that fasten the spoiler to the boot lid. Are the boot rubbers in good condition?
    97 VS Series II
    Mar 2006
    Quote Originally Posted by Shaneus
    Thanks in advanced.
    Nah that's not rear 1/4 windows, that's the tail light fixtures on the boot lid, they need to be removed, sealed surface cleaned and then re attached.... fixed mine.
    I had both leaks there and rear 1/4 windows, about to tackle the rears this weekend..
  1. Drivers Side Mirror
    By parisian62 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-11-2007, 05:24 AM
  2. WTB:VT Front drivers side guard
    By Noy in forum Swap / Wanted to Buy / Trade
    Last Post: 01-10-2007, 09:40 PM
  3. Tapping comming from drivers side
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2006, 07:50 PM
  4. VL Commodore drivers side door
    By huck0487 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2005, 12:11 AM
  5. Water Leak at Drivers Door
    By Naccas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-08-2004, 01:34 PM
