i have this problem of not being able to start the car. since i took the battery out the car will turn over and has fired and ran for about 2 seconds and the will just keep turning over and not starting. what is the problem
look at the more obvious things such as fuel and spark first
checked that before i jumped on here. thats why i need help
Checked error codes? Likely to be the crank angle sensor, less likely is the dfi module. Could be fuel related too. Can you hear the petrol prime when before you turn the key all the way?
how do i find out the error codes
check error codesOriginally Posted by emptyhead
look at the thread page its the third thread downOriginally Posted by emptyhead
