need help wont kick over.....
vr man
hey all
carnt get my car to start i dont know what the problem is.... iv changed spark plugs and leads when i try and kick it over it sounds like its about to start and it just wont... the f***ed thing is that when i pull the spark plugs out they are wet with fuel and they spark... i just dont know what to do plz help as this is my first car..... :b:
adam_vr
VU manual
they say you need 3 things to create combustion, fuel, spark, and air.
sounds like you have already figured out fuel and spark, have a look around the air intake/throttle body for any blockages perhaps?
vr man
yer i have cleaned the throttle body out already i just dont know what it could be.....
adam_vr
VU manual
did you do a throttle body clean before or after it started to happen?
other than that.... umm you definately sure all plugs are sparking? could be a distrubutor problem
vr man
yer i did it both times before and after... yer they spark but i dont know if they might be out of time or something.. what u mean by distrubutor problem??
sixshooter
2x VS
LOL...They stopped putting a distributor on the sixes back with the 202 VK...
I reckon most probablly the crank angle sensor stuffed... do search for the code page on this forum and check what fault code you have...there's a tuto somewhere on here...here it is...
http://forums.justcommodores.com.au/showthread.php?t=22307&highlight=fault+codes
ssute57l
VYII SS UTE
The fact that the plugs are wet with fuel could be no spark or that it is dumping to much fuel caused by maybe a faulty temp sensor etc, remove your fuel pump fuse and try and crank and dry them off.
have you checked that all cylinders are sparking?
Just a thought
Name of thread should be not firing as it is kicking over.
vr man
i just found out that some times they spark and some times they dont
