while doing the brakes i also checked the radiator and noticed it was a brown liquid inside. I was wondering what would cause this
could be a few things wrong. the tranny fluid could be leaking in, or there cuold be motor oil gettig into the water somehow. This could be caused by a blown head gasket or cracked head.
how do i check if the head is cracked
Take it to a radiator place and ask for a pressure test....there should be a slight brown slick in the coolant as they put in anti leak blocks aswell when they change coolant as a precaution... but if it's full blown brown... then get it checked out.
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
It could just be a bit rusty or the radiator cap is detiorating..
Most of the time a good flush out of the system will cure everything, unless things are as serious as a head gasket etc..
id say that the brown in the coolant is rusted pieces of your water pump....could be other things, but thats what is would most likely be.
