Results 1 to 14 of 14
Thread: Ive got $2000 to spend. Want to modify my engine. What to do?
    VS SIII CAPRICE
    Feb 2006
    vic
    Default Ive got $2000 to spend. Want to modify my engine. What to do?
    Hi Guys
    Last night i dragged a VT commodore with pacemaker extractors, exhaust etc. and we were side by side the whole way. I think thats pretty good for a Statesman to keep up with a commo. My car is stock in every way.
    I have decided to do mods to the engine. I have $2000 to spend on the mods.
    Just wondering on what people suggest i should do? No superchargers or turbos please.
    Any suggestions would be great.
    greatone is offline vuss
    vy ss
    Jun 2005
    id get cam and chip package stage 2 that will give good amount of power, is urs 8 or 6
    VY S2 Berlina
    Jul 2005
    Wide Bay, Queensland
    mite think about getting your heads worked, exhuast, cold air, cams etc,as greatone said
    cacaman's Avatar
    cacaman is offline Red is Faster
    Vr Acclaim
    Mar 2006
    Mods that can hurt the pocket:
    Pacemaker extractors with y piece, redback or lukey cat back sports exhust system, cold air intake.
    Mods can't really hurt the pocket:
    Clean throttle body, remove belmouth
    This is what ive done to my Vr accliam and ive had it since stock, runs to much better and im much more happier with it then when i first owned it.
    fabz's Avatar
    fabz is offline I Can Do Science Me
    Blown V6 VT commodore 5 speed
    Jul 2005
    In My Car!!
    Quote Originally Posted by cacaman
    remove belmouth
    I have never heard of that?? can you tell me what and how to do this to my vt? Cheers
    .:Blown VT V6, DAJ37:.
    VY S2 Berlina
    Jul 2005
    do a search mate :P its a fairly common and easy mod to do, also replace gaskets while you do it, if all else fails goto thr 'Howto section'
    RevHead1313 Guest
    Your VT will not have 1, only the 3.8L buick motors from the S2 VN and up have them.
    TJ
    VS SIII CAPRICE
    Feb 2006
    vic
    Thanks guys
    Its a 6. How much does all that cost the chip, heads, cam and that i would like to buy the exhaust last if possible. And what about the power increase?
    Thanks
    VS SIII CAPRICE
    Feb 2006
    vic
    Im looking at some 1:9:1 Yella Terra Rockers or some FIT 1:9:1 Rockers. They seem to make a big improvement. Do they need to be dyno tuned or have the chip remapped?
    Im also looking at a Twin Cat Exhaust System with Pacemaker extractors for $1200
    How much of an improvement does a Cam make compared to the Rockers?
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    Cam will give you a better results than just rockers, but more expensive. If you only have 2000 to spend, i would be looking into cam+tune packages from places like crow cams
    VS SIII CAPRICE
    Feb 2006
    vic
    So i would get more power out of a cam and tune than i would out of a twin high flow exhaust system and rockers?
    Are Crow cams the only ones that make cams for the ecotec?
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    yeah, a cam grind and tune would be more worth your money.
    rockers are alright, i have some 1:8:1 stealth rockers on my ecotec...they're not a big boost of power on their own though, and for what they cost you its hard to justify getting them.
    heaps of places do cams for the ecotec, id invest in a C.O.M.E. racing cam and chip package...its about $1k or so (just for parts, account for labour ontop...unless you can do it yourself)
    VZ LS1 Calais
    Dec 2005
    South Brisbane
    just had another thought...changing your diff ratio to 3.45 would be an idea if off the mark acceleration is your goal.
    a cam grind, chip and 3.45 gearing would probably just scrape in at $2k...and it would be a healthy improvement.
    semi is offline GOD
    VR exec wagon
    Aug 2005
    WA
    i meant get an exhaust as well, most of the tunes that some with these packages will account for a good exhaust and complement it.
    Just beware that if you get shorter diff ratios, your top end will suffer, and economy will suffer on the highway
  1. VX II S PAC Mods. 2000 to spend
    By steveo in forum V6 Development And Modification
    Last Post: 14-10-2007, 08:29 PM
  2. can you modify a vx vy ss cold air to fit onto a vt v6
    By Vt_vic in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-02-2007, 05:49 PM
  3. How Do People Modify
    By tr3nt in forum The Pub
    Last Post: 27-07-2006, 08:07 AM
  4. $2000 to spend on vy mods
    By Elite58 in forum V6 Development And Modification
    Last Post: 21-07-2006, 05:58 PM
  5. Ive got $2000 to spend. Want to modify my engine. What to do?
    By HIROLLA in forum V6 Development And Modification
    Last Post: 05-06-2006, 10:46 PM
