vs turbo system almost complete more pics soon
garrett gt35/40r 700hp rollerbearing turbo .86 exhaust .70 compressor
50mm external gate
custom s/steel ( steampipe ) turbo manifolds
50mm billet b.o.v
liquid/air intercooling system ( under bonnet )
vortech f.m.u
3 inch dump pipe ( and screamer pipe from wastegate )
teflon s/steel braided oil feed lines , oil sender t
oil drain lines barbs and fittings
water lines and fittings
wolf 3d ecu
42lbs high flow injectors
255 ltr walbro fuel pump
custom 3 inch throttle adaptor plate
all silicone hose/t-bolt clamps gaskets and fittings
prices from 6999.00 stage 4 complete above parts
12 months warranty on all components!!!
these systems will require modification to the exhaust to suit dump pipe
kits can be fitted to standard engine running low boost application although these systems can support 600hp on purpose built engine ect
these are tuner kits ( please refer to suitable engine specialist for fitting and tuning )
How much for entire kit + all work, drive in drive out?
yeh i wanna know that also
