LisnM8
- Jun 2, 2006
- 99
- 0
- 0
- VS Statesman 5Litre
Guys & Girls really need some help, my 5 litre stato is still overheating in these freezing conditions, wtf...its been a constant battle with this car to keep her cool, and its getting the better of me...OK water pump was a jap one so replaced it when it **** itself the other day with a genuine holden one as there propellers sit closer to the block and are more effective...still no luck, changed the cap, raditor was reco'd about 2-3 years ago by previuos owner, tryed new themostat no luck so drilled holes in her to allow a little more coolant to flow still no luck, i have been told to take the thermo completly out but i was also told by another mate it will overheat the motor more because the coolant will flow to quick not allowing it to soak up the heat from the block...mind you this is freeway driving and she sits in the notch between H and halfway ie 3/4+...one thing i noticed you know that black peice of plastic thats attached to the bottom of the radiator my cars has been taken of it usually sits bellow the bumper if you look at the front of your car does that serve a purpose to deflect air onto the motor?????Also could it be a faulty heater water valve ???? ANy suggestions please help before she blows up:bang: ANd its runnin antifreez i just put some in yesterday and she's not losing any coolant....
