M
Masher64
Guest
Twice in the last 3 mths my ride has gone into "limp home " mode when starting off in the morning...the trans stays in second and wont lock up.
This is "cured" by turning off the ignition and restarting....
I did the "paperclip and count the flashes thing" and got Code 72.."VSS intermittent"...further research and a chat with my tame mechanic I came to the conclusion that the VSS unit throws occasional "fault" readings to the ECU...the VSS on the trans extension housing is about $280 to replace..any ideas as to whether I should give it some time to get worse or does it reallyneed to be replaced ? Doesn't seem that anything too bad can go wrong?
