Hey guys, I am in the middle of changing my radiator. The new one is in, its just sitting on the bottem pins. I just need to know how I replace those clips that on either side of the radiator.
Slip the rubber block on the radiator mounting pins BEFORE you slide the radiator in. Then locate the rubber blocks and squeeze the spring clip with pliers to let it clamp the rubber block.
