Results 1 to 4 of 4
Thread: Water coming out of floor vents
    Phiness1 Guest
    Default Water coming out of floor vents
    Ive got water that comes out of the floor heating vents when the climate control is on in my VR Calais and makes the floor mats wet and slippery. It only seems to happen when i have the climate control on. Just wondering if anyone has any idea on the problem and a way to stop it? Thanks
    VE Berlina International II
    Nov 2003
    the drains may be blocked, um there is a thread some where on here to unblock it ill have a look
    Here it is
    http://forums.justcommodores.com/showthread.php?t=2495
    Thats all right, thats ok, I drive a commodore anyway!!!!
    VE SSV Sportswagon, VK race car, Kwaka ZX12R!
    Oct 2003
    Bayside Melbourne
    mate
    the water collection tray under your a/c is full
    and water cannot get out...your outlet is blocked!
    happened to me on the Berlina....
    stick a bit of wire up the outlet ...from under the car
    and check inside...from the passenger side
    that the foam (polystyrene foam is used)
    on the bottom of the housing is also not blocking the
    water outlet.....look down the floor outlet on the side of the
    a/c case on the pass side....
    no floaty foam bits should be seen...
    use long nosed pliers to remove....
    hth
    Smitty...with the VE SSv SII Sportswagon, VK race car and... Kwaka ZX12R
    Phiness1 Guest
    Thanks mate i will have a look and tell you how i went
  1. Water on Drivers Side Floor.
    By Onecontrolfreak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-02-2007, 01:23 PM
  2. no air coming out of vents
    By lilmoz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-06-2006, 11:16 AM
  3. Water coming out of exhaust!! need help
    By mattis96 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-01-2006, 05:11 PM
  4. water on the floor
    By VRFURY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-08-2005, 10:19 AM
  5. Smoke Coming Out Of Air Condition Vents
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-07-2005, 07:24 PM
