WiLo
last week i got the aldl connector off here, and using efilive i got the error codes. it shows up 13 which is O2 missing, and then 14-17 which are ECT related with volts high volts low and volts unstable, and then on top of those
19,21,22 which are TPS stuck, volts low and volts high. my fuel economy is crap to say the least, but when i look at the dashboard display on efilive the O2 senors(well im assuming that its the O2 sensors correct me if im wrong) the O2 sensors are giving off a signal that changes the values.
screen shot is just after going off throttle can someone tell me if im right in assuming i need new O2 sensors, ECT sensor and TPS?
dash display
Error codes
dash display
Error codes
