Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VR - VS Holden Commodore (1993 - 1997)
VR - VS Holden Commodore (1993 - 1997) Talk about anything relating to the VR - VS Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 15-06-2006, 06:43 PM
adam_vr's Avatar
Ride: VU manual
Trade Rating: (0)
adam_vr Executive
Default headlights out
last night i went to drive away from my girlfriends place, her street has quite a few street lights in it, but when i got into the darkness i noticed that my headlights werent working, then they came on. Now tonight they just arent working at all. parkers and highbeam still going.
Now i checked the relay and all the fuses, they seem to be all ok. ohh so are the bulbs. Im getting power to the relay as i checked with a lead light. But what im wondering is, could there be a loose connection after the relay somewhere? is the headlight switch before or after the relay?
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 15-06-2006, 07:06 PM
GOD
Ride: VR exec wagon
Trade Rating: (0)
semi Berlina
you checked the relays underneath the bonnet right? From what i can recall there are separate relays for each headlight, so it doesnt sound like a relay problem. The headlight switch is before the realy, but a relay has a trigger (eg from the switch, + and -), a power (eg from the battery) and an output (+ to the headlight). Check all of these
  #3
Old 15-06-2006, 07:19 PM
Ride: VRII Acclaim
Trade Rating: (0)
kopper69 Statesman
Now are you saying that low beam doesnt work at all? Does it work when you have hi beam on? I found that my low beam wouldnt work, but when i flicked to high beam they all worked. I followed the wiring diagram and found it to be the fog light relay. Even though I dont have fog lights, the ground from the low beam goes through the fog light relay. Did you check the fuses inside the car?
  #4
Old 15-06-2006, 07:31 PM
adam_vr's Avatar
Ride: VU manual
Trade Rating: (0)
adam_vr Executive
yeah checked the fuses inside under the steering column, didnt have a diagram stuck on anymore but i checked them all.
and yeah the relays and fuses under the bonnet, im pretty sure there was only one for headlight, and yeah you can hear it click when you turn the lights on. switched it over with the high beam relay, highbeams still worked and still no headlights.
As for looking if the lowbeams are working when the highbeams are on, im not really much of a fan looking into the bulb when the highbeams are on. The filaments are in the one bulb arent they? plus theres an extra highbeam bulb isnt there, the ones closest to the grill?
But i'll definately check out that fog light relay, i dont have fog lights either.
  #5
Old 15-06-2006, 07:44 PM
adam_vr's Avatar
Ride: VU manual
Trade Rating: (0)
adam_vr Executive
ohh legend, just went out to check it out, tried the lowbeams again and they still werent going, so i switched the fog lamp relay with the LP. CHK relay (not really sure what that is but was the same 5 pin relay) and yeah they worked, switched the relays back and they still worked so im thinking maybe terminal tension of that fog lamp relay, or a sticky switch inside the relay if thats possible. But seems to be all fine for now anyways
  #6
Old 16-06-2006, 05:43 PM
Ride: VRII Acclaim
Trade Rating: (0)
kopper69 Statesman
Clad to help. Go and get a new relay from holden mate. The old one is not clicking over properly. Because you bumped it around it will work again for a little while, but will soon fail again and cause you problems. Holden is good for these 5 pin relays. Just tell them its the fog light relay off a VR (VS's dont use the 5 pins). I think they are like $15, which is a decent price.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
Exec/Acclaim Headlights --> SS Headlights for $80 ... nEb. VY Holden Commodore (2002 - 2004) 0 04-12-2007 02:02 AM
headlights VTPREDATOR VT - VX Holden Commodore (1997 - 2002) 3 22-11-2006 09:28 AM
VX Headlights scottmitchell VT - VX Holden Commodore (1997 - 2002) 7 25-10-2006 07:53 AM
Anyone after some SS headlights? Troy711 VZ Holden Commodore (2004 - 2006) 0 02-10-2006 09:16 AM
WTB: VX SS headlights VT2VEight Swap / Wanted to Buy / Trade 0 22-05-2006 05:54 PM
Personal Loans | Personal Loans | Vienna Hotels Website | Online Gift Shopping | Free Ringtones | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
