Holden4fun
Hi,
The small pulley on the spring loaded belt tensioner seems to be getting a bit noisy on my '94 VR. It is the one with the bolt on it near the power steering pulley i.e the one you put a ring spanner on to unload the belt tension when changing the belt. Is this easy to change. Do you just buy a new pulley and bearing and is it held in place by the hex bolt? That is unbolt the old one and bolt up the mew one?
Thanks for your help in advance.
MC
MC
