Thermo Fan And Air con problems!!
Disturbed_vegeta
I'd Prefer To ROAR!
34
Burpengary
Www.myspace.com
VR Hsv Senator, VX SS, VZ SS Ute 6L, K9 GSXR1000
hey u have a problem with my vsII wagon. well first with the aircon i turn the switch to 1 then 2 and nothing happens but it works on 3 and 4!! can any 1 explain wats wrong??. also my thermo fan isint working at all and ive made sure that its all pluged in and that but im just unsure wats wrong with it so can any 1 help me? also does any 1 know if the climate control from the vr-vs hsvs and statesman works in a normal vs insted of the standard 1 without to much stuffing around??
Infus10n
Holden Captiva (Work Demo)
The aircon is the fan speed resistor... about $50 to replace from holden, there is a how-to on replacing it in the how-to section. Takes about 10 minutes to do.
RVN 355
WEST SUBS
91 VN SS 355
v good post ! :)
Infus10n
Climate control to replace normal aircon is too hard and expensive to do. But if your dedicated enough and have the parts it is doable, not easy but.
maginoodle
vy series2 ss crewman
so will replacing the fan speed resistor fix both fans??
no.it will fix your interior fan only.
the thermo only comes on when the coolant reaches a certain temp.the thermo fan has its own relay and fuse. check them first. Does the thermo come on when you turn the aircon on? If it comes on when you turn the aircon on but doesnt work any other time the sender that goes to the thermo is probably no good.
C
Cooldude1983
Guest
Vegeta, out of interest, I presume your car is overheating then, w/out the thermo fan going?
maginoodle
the aircon is fixed now but the thermo fan doesnt work at all i think it just might of **** itself
if you find the 2 wires coming from the thermo, you can hook up direct power and earth to check if the thermo is workin. you can also check if power and earth is going to the thermo.
