stalling when brake
shindiger
vs s2
Hi all,
Car: Vs S2 LPG/Petrol
my vs s2 has developed a problem and its really p*ssing me off. The problem is; the car will stall when i brake. Unless i pull up to a smooth stop, the damn thing will konk out!....and it always seems to happen at the worst possible times ie. peak hour traffic!
It wont happen on petrol, only on the gas. It started out only when you braked really hard! but now its getting worse.
Local gas man wants $77.00 per hour to find the prob. what i want to know is if anybody has come across this before, or any suggestions to what the problem might be before i take it in to the gas man.
thanks in advance
shindiger
vs s2
Hi Jack,
the car idles fine. there are no other obvious symtoms, it drives good, ecomomy is good, power when you need it etc. The only prob is when you want to stop. If your using gas, you need to come to a nice smooth stop, if not the thing will stall.
TheForgotten
only human......
quarantine
www.holdenscene.com
VR EXEC
be like us. don't use gas!
but the only helpful thing I can suggest is maybe a vacuum leak in the brake booster. My VR used to do this, never worked out what was wrong, it just stopped. but that's no help to you. I say it's your booster
kopper69
37
VRII Acclaim
I dont think this is going to help, but have you tried pulling the error codes? I dont think it will give you any though.
C
Cooldude1983
Guest
Hi Shindiger,
My mate had a similar problem with his VR, though it ran on petrol and not gas. It turned out to be a loose spark plug lead, fixed the problem and it never came back.
aa23
60
Melb.
VS Acclaim
Sounds like something electrically associated with the gas system. Smooth stop, okay. Hard braking, and a wire is shorting out, or moving more due to the harder braking forces.
SaGe
VS II S-PAK Manual
this is the same thing that happens on my mums ford, it starts to stall if u brake hard but if u let off the brake it goes fine, not sure if it only happens on gas though, might happen on both
V
VR-commo
Guest
Hey, had a simmilar problem on my ford when i first got it converted to gas. My ford wanted to stall if i hit some bumps, it turned out to be a loose wire on the solanoid valve near the converter. I suggest that you check all your earth wires on the solonoids, there may be a loose one that is causing your problems.
Good luck
vh-holden
darwin
VS sedan and a VK DRGWGN
i filled up the tank for $27 dollars this week.
as for stalling, mine comes and goes, depending on how warmed up it is. I think the problem is to do with just going from decent revs to almost nothing in a short space of time.
I've been told to check the spark plugs and leads first.
