+ Reply to Thread
Results 1 to 10 of 10
Thread: VS wont shift into Park following work on stereo
    VS Executive
    Jun 2006
    Default VS wont shift into Park following work on stereo
    Hey
    I finally managed to secure my stereo in without backstraps by bending the metal back, cutting it, drilling a hole and screwing it into the normal screw holes. I couldnt have done it without the phenomenal guide on this site -- thanks guys!
    Anyway, while doing this i had the car in 1 (transmission stick all the way back) for convenience... now the bloody car wont go into park!!!
    All of the other gears work fine, but the bloody thing just wont go into park -- i have to turn it on with the transmission on neutral...
    What do i do?
    VR Berlina auto s2
    Aug 2005
    the shire!
    my guess would be that the plasic strip that surrounds the gear stick cannot slide all the way up cause you have something blocking it.
    does this make sense?
    VR Berlina auto s2
    Aug 2005
    the shire!
    VS Executive
    Jun 2006
    Quote Originally Posted by Snotty
    i thought about that but i put it back in exactly as it was....i double checked that as i suspected that that might be the case.... unless it's hitting some wiring or something.. ill have another look... LOL aint i gonna feel stupid if youre right -- although i hope you are!
    VS Executive
    Jun 2006
    umm nah, no luck... i completely removed the plastic strip and its the same
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge Nobody Actually Berlina
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
    VS Executive
    Jun 2006
    hrrmm, yeh maybe i was inadvertently leaning on it or something... i can't be sure... makes sense though...
    ill have the mechanic have a look at it... dont think theres anything i can do
    azkwazere is offline Ahhh Yes, Ahhh Yes.... azkwazere has disabled reputation
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Just take off the center plate and try moving it into park... lift the handle and see what it is fouling on.... its gotta be something... If it doesn't shift into park with anything around it... panels etc... then its something internal... Try simple things first.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    maginoodle's Avatar
    maginoodle is offline Donating Member maginoodle Berlina
    vy series2 ss crewman
    Apr 2006
    you could have dropped some insulation tape or something on the selector track that will stop it from going into park.
    VS Executive
    Jun 2006
    HAHAHAH GOT IT!!! THAT DAMNED GUY
    THere was some sticky tape on the stick which i presumed only held on the handle but it also acted to lift the little rod that actually allows you to shift gears.... (the previous owner removed the button/lever thing so that he could shift gears without having to press anything)... I found this quite precarious because what if someone were to accidently shift the car into reverse while im driving? (you get the point)...
    I'll post a pic soon. phew!
+ Reply to Thread
  1. Brake lights work in park but not in drive.....
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-12-2007, 10:58 PM
  2. VR wont shift to 4th????
    By gupatrol in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2007, 05:13 PM
  3. It wont start in park?!?!
    By patullose in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-01-2006, 11:56 PM
  4. Wont shift to second!!
    By sniperVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-11-2005, 11:15 PM
  5. park lights don't work - VT I Acclaim
    By savage1987 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-05-2005, 09:50 PM
