WiLo
need some help with the transmission cooler hoses(the rubber ones)
one of the hoses is leaking and the clamp has decided to break on me so im going to need to get the hose off to put a new clamp one so i figure i way aswell replace the hoses aswell while im at it as they seem a bit hard.
what do i need to replace them? should i just measure up how much i need and then go to repco opr something and get a length of hose then cut it and put it on or is there something that needs to be specially done to it? as far as i can see its just a case of take hose of put new hose on and do up those little clamp things.
is there any special rating the hose needs to be? im guessing something that can take high pressure?
i know its a bit vague and might be a little hard to understand but i cant word it properly
