Results 1 to 2 of 2
Thread: Help asap with castor rod bush
    hsv14u Guest
    Default Help asap with castor rod bush
    Heys guys i was just wondering if anyone has had to replace the castor rod bush which is at the very front of car where the castor rod bolts on to. At the moment i have dropped the x arm and castor rod came out with a lot of force needed. Now i have replaced the bush but cant get the castor rod back through the bush. Any help would be appreciated
    Slow VR's Avatar
    Slow VR is offline Another White Crummodore
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    U mean the big bush at the front of the subframe? I think i flogged the fu*k outta mine to get it out. I ended up dropping the the lower control arm n did the bushes on it as well. Pretty sure i ended up flogging the fu*k outta it to get it back in....
  1. Independent Rear + Castor/Camber Kit + Lowered Coils
    By vzute2005 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 17-08-2010, 09:57 PM
  2. Problems with castor/camber angles in front end while lowering vx?
    By DavidPartay in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2006, 10:22 AM
  3. castor rod bushes
    By deckadi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2006, 05:06 AM
  4. Castor?
    By damianison in forum VL Holden Commodore (1986 - 1988)
    Last Post: 27-05-2006, 12:16 AM
  5. castor kits
    By bangers in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-04-2006, 09:09 PM
