R
Ravager
Guest
Hiya All,
Wondering if someone could offer some help?
The car has been running fine for the past few years but just recently started getting problems . Stalls, engine light coming on, Occasional gear stuck in 3rd with engine light (Auto Trans).
Did an engine fault test on the VS SS and got the following
12 - Normal Correct Operation
16 - ECT Sensor Voltage Unsteady (Electronic Coolant Sensor will replace depending on how $$)
35 - Idle Speed Error (Would this be related to 42?)
42 - Ignition Bypass Circuit Failure (Is this is this part of the Distributor EST circuit?).
72 - Vehicle Speed Sensor Intermittent While Driving (I've tried replacing the sensor on the transmission. However still there could it be a wiring problem).
Can anybody give me a little more insight to these problems?
The Engine seems runs OK apart from it stalling a couple of times at stop lights or corning.
Any help would be much appreciated.
Thanks...
Thanks...
