M
maestro
Guest
Hey everyone, i need help.
Ok so this is what i figure, the red LED lights flashes when key is out of ignition and immobiliser is on. When you put in the key and turn the ignition on the LED should stop flashing to show the immobiliser is now off. Then when you turn the key to start the engine should kick over and start. Well, when I turn my key's ignition on the LED still flashes and if I try to start it it just keeps trying but won't obviously cuz the immobiliser is on still. If i fiddle around taking the key out and turning the ignition on and off the LED stops flashing eventually (can sometimes take up to 5mins) and then when I turn the key the car starts fine.
I'm wondering if anybody know's how this stock immobiliser works and what my problem is. any help would be muchly appreciated
