Results 1 to 4 of 4
Thread: How do I replace VR wagon gas struts??
    comblydore Guest
    Default How do I replace VR wagon gas struts??
    Hi guys,
    The gas struts which hold open the tailgate on my VR wagon are totally shot and won't stay open at all - you have to actually use one hand to hold it open which is a pain in the butt.
    I have ordered a new set of aftermarket replacement ones which should be here any day. I'm a bit of a novice, so could someone please expalin to me in simple terms, how I remove the old ones, and how to fit the new ones???
    Any help much appreciated
    VL Berlina
    Oct 2005
    If they're the ones i'm thinking of, theres a little metal clip around the heads on both ends that you lever off with a flat head screwdriver or the likes of...
    the strut should just pull off easily once they are off, then put the new struts on over the balls on each endand push the clips back over the heads.
    VSII Executive
    May 2006
    yeah mine are rooted too, Im goin to order in new ones soon but havnt got around it it yet, atm there is nothing on it at all and you can see how heavy a boot really is its crazy, these little buggers hold up a lot of weight no wonder they are buggered. but yeah do asMatty081 said, make sure boot doesnt fall on ur back, it hurts
    VS Berlina Wagon
    Mar 2004
    Melbourne, VIC
    Quote Originally Posted by Matty081
    Something I learnt the hard way -- don't pull the clip all the way off,
    just lever it off enough so that it's not holding on to the little balljoint
    thingy. If you pull the clip all the way off you have a hard time getting
    it back on.
    A little smear of grease on the ball before you pop the new one on
    is also probably a good idea.
    Cheers,
    DP
  1. WTB, vl wagon boot gas struts
    By bensta in forum Swap / Wanted to Buy / Trade
    Last Post: 13-04-2006, 02:15 PM
  2. Wagon struts
    By rattattack1313 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-10-2005, 12:47 PM
  3. replace VX S2 radio CD unit and back door speakers on wagon
    By jaclyn in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2005, 03:58 AM
  4. Replies: 0
    Last Post: 16-10-2005, 05:41 PM
  5. Gas lift struts for wagon hatch
    By deeranp in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-06-2004, 12:07 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
