ssmate
hey, after i filled up the other day i noticed there was a slight power drop just from 1st to 2nd, meh,didnt take much notice! (thought it was beause i was using 98oct then filled up with 95oct) anyways bout a day later with same sluggish gear problem. I was putting work gear in the boot and i could smell petrol really bad! took a look under and i found it is leaking from the fuel tank! bloody spewin! just wondering if any one has had this problem b4? if so how much was it to fix! can the hole/crack (not sure) just be patched up or does it need a complet new one? also would it be safe to drive round with as wont really be able to get to mechanic till the weekend! it leaks about half a litter or so a night going from the drip spot on the ground!
thanks guys
thanks guys
