Results 1 to 7 of 7
Thread: VS heater problems.
    VT1 S/C 3.8 S Pack
    Dec 2005
    Default VS heater problems.
    My VS heater sometime works and sometimes does not.
    When workin it works perfect and all fan speeds work well.
    It is a vacationer so just a basic heater (no climate controle)
    When it dosen't work nothing works.
    There also seems to be a link with the rear heated demister, because when the heater is working properly and I hit the rear demister button, the heater fully cuts out!!!! (including the rear demister) weird. and about 10 minutes later after turning off the rear demister the heater will start to work again.
    Also sometimes everything works perfect , Heater and rear demister.
    But definately if the rear demister is working, the heater always works.
    Now that should have confused everyone, but any help on this matter would be greatly appreciated. I need a reliable heater and rear dmister ITS COLD.
    Nick.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Try changing the fuse as maybe its not making proper contact. Not sure if there is a relay under the bonnet for the heater fan as well. As a last guess it may be the resistor block failing - this will kill all power to the heater. Good Luck.
    VT1 S/C 3.8 S Pack
    Dec 2005
    I have changed the fuse and the relay, but the heater still plays up.
    Buy the way what is the resistor block.????
    can I change this.
    Thanks.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    SlyVR's Avatar
    SlyVR is offline Fo'sizzle....
    VR Wags
    Nov 2005
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by SlyVR
    hey iam having the same problem right now.. can anyone please help
    Have you tried the above fixes?
    VRII Acclaim
    Jul 2005
    The 'ignition relay' next to the fuse block inside the car (under the steering column) runs both the interior fan and demister. A relay would cause this intermittent problem.
  1. heater problems
    By coota in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 11:38 PM
  2. heater control problems!
    By lilkel in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-08-2008, 12:02 PM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. Heater problems help!
    By V8chick in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-07-2005, 03:18 PM
  5. Heater And Blower Problems
    By pcp20us in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-01-2004, 12:10 PM
