20x8.5s on a VS?
SaGe
VS II S-PAK Manual
will 20x8.5s fit on a VS?
as far as i knew 19x8 was the biggest u could fit but the guy down at autopro said it would fit with no dramas, is he tellin the truth?
VR_Project
Bunbury WA
MWS Improved VS Ute
might need to roll the guards and extend a couple of things first... but where theres a will theres a way :yeah:
statement
reaching new limits
north but not to north
VY/VZ Calais/Tonner
yer man like VR_Project said, cause 20z are getting more common on vs's an i spoke to a guy about fitting 22z, he said no worries but the tryes will wear alot quicker, but 20z won't be a big as a problem
hayds_12
Lameroo, SA
VS Commodore Series 2
i want to kno how much space is under those ve arches if the ssv comes standard with 19s anyway im waitin to get me sum of those
and as VR_Project said (where there is a [wheel] there is a way)
VR_Project
Bunbury WA
MWS Improved VS Ute
i hear that the VE can fit 20's in the wheel arches without adjusting anything at all...may have been a rumour, but if u could then thats wikid!:D
sircruisealotVS
39
South Brisbane
VZ LS1 Calais
20's will fit, thats no problem...having it legal is where some other moddification come into play.
in order to have no scrubbing you will have to pump and roll the guards...how you setup the suspension will also have to be well thought out, as having such large rims make suspension travel pretty scarce.
shortened bumpstops, short travel adjustable shocks, and the right choice of springs (most likely not much lower than stock) will be needed.
you will also have to have get a mod plate to keep authorities happy.
holden007
VRII
Subaru Liberty
20' let alone 22' rims, very expensive and rough ride.
_Mukas_
DJ Titan...Hardstyle guru
Edithvale born n bred...
VR 5.0L Statesman
and youll look like a muzzlord, a wannabe gangsta, or just a plain wanker with 20"+ on a commo.....
HIROLLA
vic
VS SIII CAPRICE
20z fit well atleast on my Statesman 20x8.5
No rubbing or rolling or anything.
