+ Reply to Thread
Results 1 to 9 of 9
Thread: Bonnet release cable snapped how do i open the bonnet
    S-Pac_Sam's Avatar
    S-Pac_Sam is offline Constantly Sideways! S-Pac_Sam Executive
    VS Commodore S V6 Manual
    Nov 2005
    Sydney, NSW
    Default Bonnet release cable snapped how do i open the bonnet
    hey all,
    went to check my oil this morning and as i pulled the release lever the tension disappeared just touching it and now the lever is loose as.
    how do i get my bonnet open?
    VR Caprice
    Dec 2005
    If you can get in tight at the front you might be able to do something from in front of the Radiator. I mean you might be able to get a screwdriver up there and release it or something. If your in the NRMA or your states equivlant give them a ring.
    Apr 2006
    Last time I did that, had to do it on the ex's parents VT which had flat battery (car was full dead locked)
    Managed to get up inside from under the car and pulled the release with a screw driver.
    AdamIan69 Guest
    I did the same thing on my VN, i just reached up from under the car, and pulled on the cable from in front of the radiator.
    gc08wgn is offline Donating Member gc08wgn Executive
    vs 5ltr statesman wagon vs 5ltr caprice
    Feb 2010
    brisbane
    big bladed screw driver and unscrew the bonnet peg but b4 you do that just pull kick panel off and check if you haven't just broken the handle for the release plastic usually brakes b4 metal
    vz s pack ute
    Nov 2008
    Alstonville Northen Rivers NSW
    vn_v6's Avatar
    vn_v6 is offline Blumpkin vn_v6 Executive
    87 vl limited edition
    Aug 2009
    victoria
    a brick, and a good throwing hand, pick cheapest window (not windscreen )
    Quote Originally Posted by Swordsy View Post
    If keyboads were cars, I'm sure half the people here would have been run down by now :P
    Quote Originally Posted by danja View Post
    GM: Has millions of dollars and highly trained engineers.
    Some guy in his backyard: Has a hole saw.Discuss.
    Quote Originally Posted by illusionalvr View Post
    just tow it around on a trailer and tell everyone its a turbo putting out 770 horses.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by vn_v6 View Post
    I didnt know the bonnet had windows and a windscreen.Must be so you can see the engine from the outside.You learn something new every day.
    Brucefromruse is offline CRAVEN MOORHEAD Brucefromruse Executive
    VS executive s2
    Oct 2007
    Campbelltown nsw
    Use a can opener.
+ Reply to Thread
  1. bonnet cable snapped how do i open?
    By Gazza2005au in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-05-2008, 05:36 PM
  2. need help! bonnet latch is broken and cannot open bonnet!
    By boourns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-04-2007, 03:17 PM
  3. Bonnet won't release
    By JoelG in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-01-2007, 02:57 PM
  4. bonnet release
    By quiksilver1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-01-2007, 12:15 PM
  5. Bonnet release cable HELP NEEDED!
    By shrekVK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-11-2006, 11:21 PM
