Results 1 to 7 of 7
Thread: Replaced alternator brushes - now what ?
    VS II 5 ltr Berlina Wagon
    Apr 2004
    Default Replaced alternator brushes - now what ?
    Battery light still comes on occasionally i.e. nothing changed after putting in a new set of (V8) alternator brushes last weekend. Time for a new regulator and how much are they or could the battery be rooted ?
    Mmmmm V8
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    could be a few things - check the battery with a multi meter, with car running, check volts, should be around 12.2-14.4 I think, and with car switched off, should read no lower than 10
    could be the voltage regulator - prety sure it won't run at all if the reg's stuffed
    could also be the diode - if the diode's stuffed, a brand new battery can go dead overnight.
    other than that, I could only suggest poor/old wiring
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Usually the regulator is replaced when the brushes are replaced as they are cheaper that way ($40-50) and they both can cause the battery light to come on. At idle with no accessories or lights on you should be reading at least 13.5V and with the engine switched off after sitting for an hour or two or overnight it should not read below 12.6V.
    Patrio7's Avatar
    Patrio7 is offline 3Y3 K4N 5P33K 1337.
    '96 S1 VS Exec
    Jul 2005
    Perth, Como
    water in battery topped up? my battery light came on a while back, battery was pretty low, topped it up, took it down and back up the freeway, all good.
    attn Über geeks, i play Second life. Patrio Graysmark.
    Apr 2004
    Thanks for the replies. I ended up getting a new reg set for $45 from my local Holden dealer. I replaced it tonight without taking the alternator out in around 15-20 minutes ( ). Hopefully that's it for now and the bat light stays off. Cheers !
    Mmmmm V8
    SLE2007 is offline SLE2007
    1982 VH SLE
    Jan 2007
    AUCKLAND
    Smile voltage regulator 1993 ss
    Quote Originally Posted by vsv8berlinawag View Post
    got a brand new battery.600cca and was happy until driving down the road the battery light came on again.
    went to holden wreckers and bought brand new voltage regulator .
    disconnect battery and replace.2 screws on back of alternator.
    turned car back on and the voltage was back at normal on battery
    and battery light on dash went off.so happy!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    9 out of 10 alternator problems are the voltage regulator !
    thats what people have been saying.
    Apr 2004
    light is still off since my last post, but since then about a month back the battery died at the local petrol station with no real prior symptoms other than it was getting hard to start on the odd cold morning. I drove in, filled up tank, paid the man, tried to start car, zip, dead and naffed. Lucky petrol station as they got $40 for juice and $135 for a new battery !
    Mmmmm V8
  1. help replaced cas and now no spark
    By HDT_aero in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-07-2006, 05:26 PM
  2. Can it be replaced
    By Just_Ice in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-07-2006, 10:04 AM
  3. Can it be replaced???
    By _Mukas_ in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-05-2006, 04:50 PM
  4. vn,vp,vr regulator brushes
    By 94 VR BT-1 in forum General
    Last Post: 14-03-2005, 12:00 AM
  5. Brushes!?
    By The1985divo in forum General
    Last Post: 16-11-2004, 10:28 AM
