Results 1 to 6 of 6
Thread: replacing front seat
    vr commodore
    Aug 2006
    Default replacing front seat
    i have managed to snap the weld that holds the seat to the runner, because of that i have to replace the front seat... being the indoor decorating type and knowing nothing about bolts could someone please tell me (in idiot terms) how to change the seats over??
    Patrio7's Avatar
    Patrio7 is offline 3Y3 K4N 5P33K 1337.
    '96 S1 VS Exec
    Jul 2005
    Perth, Como
    the rails should have four allen key screws/bolts, pretty sure its a case of undoing said four screws / bolts and then presto your seat is out.
    from there you can either get new rails [ wrecker ] or replace the seat entirely ( maybe go a VS S2 seat, its slightly more "buckety" ( better side leg support slightly deeper back )
    attn Über geeks, i play Second life. Patrio Graysmark.
    payne Guest
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    Apparently so. read this
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    VR Statesman
    Jan 2004
    Wyee
    Default Easy as Campessi
    One of the easiest jobs.
    If you have a height adjuster jack it up, there are 4 allens bolts, one in each corner.
    Pull the seat out of the car and turn it upside down and take out the 4 allen bolts, again one in each corner.
    Go to the wreckers and get a replacement set of runners and fit in the reverse.
    A common problem with people who lean the seat back too far when driving.
    Please note that they cannot be repaired as the heat weakens the metal.
  1. Back of front seat
    By nickmarlow1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-01-2008, 08:43 AM
  2. VS Front Seat Not Level
    By VQ Stato in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-02-2007, 07:40 PM
  3. Front seat removal.
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-05-2006, 07:10 PM
  4. VN front seat removal
    By ProMaX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-02-2006, 11:27 PM
  5. Replacing with bench seat
    By jodieb in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-11-2005, 07:10 PM
