Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VR - VS Holden Commodore (1993 - 1997)
VR - VS Holden Commodore (1993 - 1997) Talk about anything relating to the VR - VS Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 03-09-2006, 04:26 PM
Ride: N/A
Trade Rating: (0)
TOBSTA Executive
Default HOW TO install a pod filter on vs 3.8l
after buying a pod filter for my ecotec ute (3.8) ive found that i cant put it on as there is a sensor in the factory airbox that causes the engine light to come on when disconnected... for those with experience with this
how do you get around this sensor to fit the pod filter? help!!!!
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 03-09-2006, 04:38 PM
VEARGH's Avatar
"Stop,Drop..KaboOm.*
Ride: v_R
Trade Rating: (0)
VEARGH Executive
i would say its just a temp or oxygen sensor, best bet is to just re install it close to the pod on the pipe??
  #3
Old 03-09-2006, 04:41 PM
mattman's Avatar
Ride: '00 WH V6
Trade Rating: (0)
mattman Berlina
do yourself a favour and get a pod mount bracket... bolts onto one of the air box mount points and keeps eerything tidy, should also have a spot to mount the air temp sensor (the one you are missing now).
If you leave the air temp sensor out it will give botched readings and may run the car too lean or too rich..
__________________
  #4
Old 03-09-2006, 04:49 PM
daron's Avatar
Ride: vt 2000 series 2
Trade Rating: (0)
daron Berlina
go back to panel filter and go cold air instead pod filters are crap and suck in hot air from ya motor
ps the sesor can be left out of pod but plug it in so warnign lights dont come on
stick it somewhere cold it tricks comp
  #5
Old 03-09-2006, 08:09 PM
Ride: N/A
Trade Rating: (0)
TOBSTA Executive
'it tricks comp' what does that mean mate, and these pod mount kets, where do i find one... ohh yeah how much are k and n panel filters?
  #6
Old 03-09-2006, 08:33 PM
daron's Avatar
Trade Rating: (0)
daron Berlina
if ya unlpug the sensor it gives warnigns (not always thoguh) so keep it plugged in at all times
if ya have it in a cool place it tricks cmop thinking air is cool so it lets in more fuel and tells comp to mix it diferently
if sensor is hot it doesnt allow more fuel so ya cant kill motor
if that makes sence
  #7
Old 03-09-2006, 09:51 PM
sircruisealotVS's Avatar
Ride: VS Equipe series ll
Trade Rating: (0)
sircruisealotVS MonarosircruisealotVS Monaro
ok...thats just stupid man, why would you just chuck the temp sensor outside the intake airflow, giving off false readings.
anyway...you can get around needing a bracket to attach the sensor...just free up some of the wiring (usually invloves cutting the cable tie holding the group of wires and pulling the temp sensor wire free) and run the sensor inside the pod's rubber fitting to where it drops off to the filtering element...
then just chuck the pod on like before, easy as...it will be getting acurate temp readings and you wont need to get a bracket.
  #8
Old 04-09-2006, 12:18 AM
daron's Avatar
Trade Rating: (0)
daron Berlina
i didnt say its a good idea to place sensor outside of pod i was refering to leave it plugged in so you dont get fault codes
yes its stupid and sooooooo many ppl do it
i see it daily at work
  #9
Old 04-09-2006, 04:51 PM
Ride: VS Lexcen
Trade Rating: (0)
Crimmo Executive
Anyone know where to get one of these brackets? Or where to get a heat shield for a pod?
  #10
Old 05-09-2006, 06:27 PM
94vrexec's Avatar
Ride: vr executive
Trade Rating: (0)
94vrexec Executive
supercheap. pretty much any car auto place that sells pods sells them
__________________
hehehe
  #11
Old 05-09-2006, 07:28 PM
mattman's Avatar
Ride: '00 WH V6
Trade Rating: (0)
mattman Berlina
yeah I got mine from supercheap, $20 or so.
Keeping in mind that i did rip it out in favour of a CAI about a month later.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
VN Install draco386 Car Audio 1 05-11-2007 01:20 PM
How much to install? Noy General 0 08-03-2007 07:12 PM
XR6 Install wrx884 Car Audio 12 30-01-2007 09:36 PM
STandard AIr filter or K&N POD/FIlter KDB1972VT General 3 29-07-2005 10:16 AM
pod filter install, help needed pHiLix VR - VS Holden Commodore (1993 - 1997) 7 18-03-2005 04:40 PM
Debt Help | Refinance | Online Advertising | Mortgages | Myspace Codes | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
