Results 1 to 10 of 10
Thread: What to look out for when buying a vr
    VP Exec
    May 2006
    Default What to look out for when buying a vr
    Hi there everyone,
    im looking at buying a vr berlina and am wondering what should i look out for while looking at it and while test driving it. just a few simple things to look out for would be great
    i had a look at the vr faults section, and it just had tonnes of things that can go wrong, of course, when buying a car i cant go through all of that, so im just looking for a few things to look out for that could cause a problem later
    thanks in advance
    steve
    1990 Toyota Starlet GT, turbo.
    Jul 2005
    Hobart
    Start off checking the basics such as brake pads/discs, paint, rubber marks under wheel arches(Burnouts).
    Check for oil leaks out of the engine, if its manual pull on the handbrake and slowly let the clutch out, if it goes to stall then the clutch is not slipping. When test driving find a large area and put on full lock and drive in a circle, then other way and both ways in reverse, there should not be any abnormal noises. Drive about 40km/h and in 4th back off the accelerator then push it flat to the floor, if you get a jerk under the car before it starts to accelerate then the cv joint is worn.
    E.P.A .. Emo Patrol Australia.. We'll Make Your Life Hell <-- Add this to your signature for EPA domination!
    Chuck Norris won 'Jumanji' without ever saying the word. He simply beat the living shit out of everything that was thrown at him, and the game forfeited.
    VR 3.8 EXECUTIVE
    May 2006
    check the engin oil cap to see if there are white creamy things sticked,,
    that means water into cyclinder which will cost you much,,i just found in my vr
    VS exec
    Mar 2006
    Wollongong
    check in the bott in the spare wheel well for water, if it hasnt rained recently got a bucket of water and pour it aorund the rear 1/4 window leave it for five minutes or so then check, or take it to a car wash and put the high pressure spray around the window
    97 VS Wagon
    Aug 2005
    you can get places like automasters to do vehicle checks for you, if you shop around you can get them for like $100. they check everything and give you a sheet with what is stuffed and needs attention so it is worth it.
    [SIGPIC][/SIGPIC]
    VR 3.8 EXECUTIVE
    May 2006
    Yes RACV can do the same thing. If not so sure, give it to professionals.
    VP Exec
    May 2006
    do the raa do that kindof stuff? for free? does any1 from sa or has been from sa know?
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    The raa will do a check for you. It costs about $117 and you have to be a member do get that service. Not sure if there are any other companys that do this for you.
    PM Sent with a list of contacts.
    VP Exec
    May 2006
    VP Exec
    May 2006
    costs 102.50 through the raa
  1. Buying a SV6
    By cladiges in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-03-2007, 04:53 AM
  2. When buying a vz
    By knight97 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 30-01-2007, 05:13 PM
  3. Buying a VT SS 5.7
    By patullose in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-08-2006, 10:37 PM
  4. VN buying - what to look for?
    By mitch01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-11-2005, 08:26 PM
  5. maybe buying a vs on gas - what to look for
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2005, 06:11 PM
