Results 1 to 25 of 25
Thread: Trying to put VX SS interior in VS...pls help!!
    VS S2 5L
    Oct 2006
    Default Trying to put VX SS interior in VS...pls help!!
    Guys,
    Has anyone put in a VX interior or similar into a VS Commodore..... I have the complete interior of a VX SS (front and rear seats) and wanna chuck it into the VS Exec 5ltr.
    Where do I start? Do I need to change the rails for the VX front seats to fit the existing floorplan?
    What about the back seats- what needs to be done there? I figured people on this forum would have done this before, hence, the request for advice and assistance! If I can't do it myself and its gonna cost a bit, then I will sell the VX SS interior in the local 'trader'.
    Cheers guys.....http://forums.justcommodores.com.au/...lies/smile.gif
    Freakme
    ss thunder
    Jul 2006
    Melb
    how much for em . . . lol
    nah i help a mate put vt ss fronts in, piece of piss really just need to change the rails, not to sure bout the back? let us know how they go! they will look tops in a vs!!!
    Ghost79's Avatar
    Ghost79 is offline Thats How We Roll!!
    95 S1 Berlina
    Jun 2006
    yeah would look good but don't know how the back would fit?
    Planned Install for VS
    HU:JVC KD-AVX2 Getting Soon
    Screen: in dash 7"widescreen
    Front Stage:165v2 might have to rethink thanks to defty's advise
    Rear:165v1 owned
    Sub:33 V2 maybe? have no idea really
    Amps: Jaycar 200wrms, 300wrms owend .to be upgraded later plus Fans, maybe Monoblock
    Sound Deadening:Dynamat front doors and Boot
    Hardrive: new plans hardrive possible a ipod
    If You See Any Gd VS Please contact me really want one so install can begin
    VS S2 5L
    Oct 2006
    __________________________________________________ _______________
    ssmate,
    Your info appreciated.... if I can't get fit 'em in, you'll be the first to know.. lol!
    Do u know where I can get those rails that you are talkin' about? Can you remember what your mate paid for 'em?
    Just need to figure out now how the back seats fit in - I'm presuming that the brackets on the chassis need to be realigned or changed in some way?
    Other forum members thoughts would be appreciated!
    Cheers Freakme
    Oct 2005
    Apparently, the back seats need a little bar welded underneath and then the tab that holds them down slightly bent to fit. It is possible, a little fiddly but not difficult. As for the front, just unbolt the rails from your exisiting seats.
    VS S2 5L
    Oct 2006
    Hi Manass,
    Thanks for the info. U seem to be a little 'clued up' on the issue - so from what you're saying, I can unbolt the seat rails from my exisiting VS seats and put them on the VX SS seats, is that correct?
    "Apparently, the back seats need a little bar welded underneath and then the tab that holds them down slightly bent to fit."
    When u refer to the bar that needs to be welded - I'm assuming that this mod is for the back rest part of the back seat (upper part) yeah? And, the tab mod is for the 'bum' part of the back seat (bottom part). If I'm right or wrong, can u pls let me know.
    Your help appreciated man! Has anyone else tackled this before?
    Cheers Freakme
    Patrio7's Avatar
    Patrio7 is offline 3Y3 K4N 5P33K 1337.
    '96 S1 VS Exec
    Jul 2005
    Perth, Como
    i thought VX seats featured electric adjustment ( front and rear height at least ) but i suppose the VS rails will cover that?
    attn Über geeks, i play Second life. Patrio Graysmark.
    ss thunder
    Jul 2006
    Melb
    Oct 2005
    Freakme, the back part is pretty much straight up fit. All the work needs to be done to the base part.
    Ghost79's Avatar
    95 S1 Berlina
    Jun 2006
    post some pic of the whole procces would be good
    Rear:165v1 owned
    VS S2 5L
    Oct 2006
    Ghost79,
    Once I figure out how the back seats fit in.... I will hopefully get some pics up for every1 2 see.
    Now to work out and follow what manass has stated.... to get that bar welded and muck around with fitment. An in-depth look at it over the weekend no doubt on the cards!
    Cheers..
    VS S2 5L
    Oct 2006
    I was mucking around on the w/end trying to get the VX SS front seats to go in my VS.... I took the metal base frames off both the VX and VS seats. Should I have done that? I tried to retro-fit the VS metal base frame on the VX seats - a definite no go! They clearly don't fit!
    This in turn led me to the conclusion that I should've just taken off the seat rails and not the entire metal frames? The VX seat rails look a little difficult to take off? How would I take them off? The nuts have round heads? Am I on the right path here?
    Any posters thoughts appreciated.
    Cheers Freakme
    VS S2 5L
    Oct 2006
    Default Need some further help!!!!!!!
    Guys,
    I have hit a major brick wall..... your help would be appreciated!!! Need further advice regarding the rails - Manass, ssmate???
    Cheers Freakme
    VS S Pac S2 M5
    Mar 2005
    Whats the go? Any luck?
    VS Series 2 S-PAC 5spd manual - nicely moded for the race track
  15. #15
    BnSuter's Avatar
    BnSuter is offline Meow Meow F**kin' wow
    VS S2 S pack ute
    Feb 2006
    Victoria, I'm from the country an I like it that way!
    Hey freakme, How have you gone fitting the VT-VX seats to the front as I want to do the same in my ute. Can you just use the VX rails with the elec hieght control. Prosuming the bolt patton is the same
    My an My 904 Kickin' On Flat to The Floor
  16. #16
    vx-acclaims2
    Oct 2006
    I'm getting seats from a vx to fit into my vs so i'll let you know how i go.
  17. #17
    VS S2 5L
    Oct 2006
    Quote Originally Posted by Vs-AclaimII View Post
    Let us know how u go..... it is not an easy job! My main issue is fitting the VS front rail set-up to the VX front seats.... it requires a bit of work.
    I don't want to drill holes in the floorplan to accomodate new VX rails, so retro fitting the VS rails to the VX seats is really my only option. A bit more thought is required on my behalf.
    Cheers Freakme
  18. #18
    BnSuter's Avatar
    VS S2 S pack ute
    Feb 2006
    freakme how much differance is there between the prexisting holes from vs seats and the vx seats, i'm going to have a look this weekend, taking the passagers seat out of mums vx acclaim an see how it fits in my vs ute. Can you just drill holes in the rails on the vx seats to suite the VS body holes.
    Thanks freakme
  19. #19
    VSII Ute
    Jul 2006
    Boys, one and all!!!!!! I HAVE DONE IT!!!! Before an innocent hairs is harmed by tearing your own hair out please read on......
    I got a pair of VT SS front seats into my VS ute. Relatively easy but with a little stuffing around. If any are interested I'll go into more detail soon when spare time is available.
    To cover a few things I've read though - VT to VS seat rails very very very different and do not line up.
    I had to do away with the height adjustment but that was a minor price to pay.
    And the bases of each of the two seats do not match up - minor mods needed......
    So again, I can post in detail if wanted.......
  20. #20
    '95 VR S2 BT1 5 Speed, N13 Pulsar Vector
    Oct 2006
    S.A. The revenue state!
  21. #21
    BnSuter's Avatar
    VS S2 S pack ute
    Feb 2006
    Thanks for your help on this Countrypak when you get time to do it. Would be good if you could show some final pictures.
    Cheers mate.
  22. #22
    petezor is offline i like icecream
    VS COMMODORE
    Jul 2006
  23. #23
    AGRO_38's Avatar
    AGRO_38 is offline Formerly SLAYR
    2000 VS UTE
    May 2006
    Western Sydney
  24. #24
    ruredi's Avatar
    ruredi is offline AVGJO3
    '02 VX II Berlina Station Wagon 5.7L
    Jul 2005
    its definetely possible...I seen VT SS seats in a VS the other day down at my dads panel shop...back ones to...looked SCHMICK!!!! will defietely be on the next "to-do" list.
    Cheers, Joe
    Everything is possible for him who believes. Mark 9:23
  25. #25
    BnSuter's Avatar
    VS S2 S pack ute
    Feb 2006
    Hey ruredi I was just checking out your ride where did you get that dash cluster skin?
  1. Interior kits or changing Interior
    By iRiot in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-11-2011, 08:54 AM
  2. Replies: 7
    Last Post: 27-02-2007, 03:55 PM
  3. Interior
    By wes_v8 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 01-10-2006, 08:24 PM
  4. vn-vs interior
    By stocky in forum Swap / Wanted to Buy / Trade
    Last Post: 11-10-2005, 07:19 PM
  5. vh sle interior
    By 308commodore in forum Parts And Other Items For Sale
    Last Post: 24-08-2005, 02:41 PM
