+ Reply to Thread
Results 1 to 9 of 9
Thread: Stupid Beeping!!
    VS2 Berlina
    Oct 2005
    Pakenham, Vic
    Default Stupid Beeping!!
    I dunno which it is, its either handbrake sensor or seatbelt?? do vs' have seatbelt sensors? if not how do fix the handbrake one!!! is bloody annoying
    'I always thought xbox was a straight edge kid called bo.' :my:
    5.0 VQ Statesman
    Jun 2005
    VLishes's Avatar
    VLishes is offline BaZMeG VLishes has disabled reputation
    VS Calais SII
    Jul 2004
    If it's the same sound as the fuel low warning and beeps about a minute or two after everytime you turn the ignition on then it might be a fault with the fuel sender.
    shanhsv's Avatar
    shanhsv is offline Luvo shanhsv has disabled reputation
    VS Berlina V8 5speed
    May 2005
    Muswellbrook,NSW
    if its the hand brake,the sound will be different than the low fuel warning.Which light is on when its making making noises
    WTB:VR/S HSV 250km/h speedo cluster
    VE SSV UTE
    Jun 2005
    Outer North Eastern Suburbs Melb
    I had that annoying noise on my VR Calias and it almost drove me mad. I tried checking the handbreak switch and stuffed around with it for weeks. One day I banged the dashboard and found it stopped. It turned out to be a loose globe in the dashboard. I replaced it and had no trouble afterwards. Hope this helps.
    BF fairmont (when im allowed)
    Jun 2006
    hoppers, melb
    Quote Originally Posted by Anton View Post
    press the button on the end of the handbrake and push down?
    lmao.. i'll definately pay that one..
    im unlicensed
    check out my site: http://www.myspace.com/foxc_leelee
    if i turn my diff around, will it make my car front wheel drive??
    immortality's Avatar
    immortality is offline crappy ol' VN driver immortality W427 immortality W427 immortality W427
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    i love that little beep, stops the missus driving around with the handbrake on like she did to my old VK and when she got home she wondered why the rear brakes were smoking
    Body by Holden, Soul by Brock
    the Legend will live forever
    2004 VY2 SV8 A4
    Jun 2005
    Victoria Point, Brisbane
    AFAIK there are only 3 beeps you'll get out of the VS (unless something is VERY wrong) they would be speed alert (check it is disabled) low fuel warning (check for light on dash and fuel gauge function) or handbrake on, which only occurs if you start moving while handbrake is still on. If light is on dash when handbrake is off, then the switch is probably faulty. It is located at the rear base of the handbrake.
    EDIT: *w00t* 600th post
    2nd EDIT: VS does not have seatbelt sensors. It does, however, light up a seatbelt light on dash for 5 seconds when you turn the ignition on to "remind" you.
    * Phreddy's Blaupunkt Aux input and line out mod
    * 18x8 inch Equus Kalibur Wheels with Maxxis MAV-1 235/40R18
    * Sureflo 3.5 inch medium-loud cat back exhaust
    VS Berlina S2
    Aug 2004
    Mandurah, WA
    just fixed my beeping prob, was a dodgy handbrake warning globe
    VS Berlina Series II
+ Reply to Thread
  1. beeping in the cluster
    By slipstream001 in forum Electrical Wiring / Questions
    Last Post: 16-11-2007, 02:57 PM
  2. Stupid Driveways and Stupid Gutters
    By Miss-E in forum General
    Last Post: 09-08-2006, 01:03 PM
  3. car kept making three 3 beeping sounds???
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2006, 05:12 PM
  4. How do I fix the handbrake beeping on my new cluster
    By gdunkley84 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2006, 06:02 PM
  5. vl beeping?
    By sully in forum VL Holden Commodore (1986 - 1988)
    Last Post: 01-03-2005, 03:15 PM
