Results 1 to 4 of 4
Thread: The Trip computer
    soulyouth's Avatar
    soulyouth is offline Space Docker
    Sold for scrap :(
    May 2004
    Bossley Park
    Talking The Trip computer
    I was playing around with the trip computer in my VR Calais seeing if there were any other uses, and I found if you hold down set for a while on each of the 3 different modes you would get 3 different set up thingys
    on one of them it tells you how much petrol is in the tank (live, have rocked car and it changes realtime) and the other 2 seem to be some type of set up for the trip computer, any help as to wot these are and wot there used 4 would be great, if I didn't give enough info I will write more up on it just ask Ok
    cheers
    VE Berlina International II
    Nov 2003
    im sure one of the settings is the digital speedo
    Thats all right, thats ok, I drive a commodore anyway!!!!
    1996 VS Executive
    Jul 2004
    My mate's got a VR Berlina, and to active these 'hidden' functions, he holds down set and down buttons (if i remember correctly) before starting the car...this brings up a bunch of extra features
    from memory:
    -digital speedo
    -digital voltmeter
    -digital fuel level
    -diagnostics
    -fuel tank sender voltage
    -fuel comsumption/hour
    i think u press mode to scroll through all these displays. There is also one display where everything lites up, and the speedo and tacho go up to 100km/h........some sort of diagnostic test thingy.
    Impulse Blue VE SV6
    Feb 2004
    Newcastle, NSW
    This is actually 2 seperate things being talked about .. the VR/VS Trip Computer (3 window) has 2 different modes of hidden details.
    One is to hold down "SET" while your in normal mode, and depending on which of the 3 mode screens you were on, you get different details. As the original poster mentioned, one is a real time fuel level indicator, the other 2 are calibration details used to optimise the trip computers readings .. pressing up/down while holding set on these 2 screens will alter the detail. One if FLO-CAL, the other is DIST-CAL i believe .. relating to distance measurement (probably needed if you change rim size/tyre size drastically?) and the other is the measurement calibration for the ammount of fuel consumed .. ie, the flow rate.
    The other mode is to hold the buttons down while starting the car, and you get the 3 screens mentioned by the other poster. On the "diagnostic" screen, which lights everything up, you should also get a constant buzzing from the beeper, to test its working. Press mode again to switch back to normal. Pressing mode/up again will revert to normal display mode.
  1. Resetting your computer and trip computer special functions (VT - VX)
    By Darren in forum Holden Commodore How-To's
    Last Post: 19-01-2011, 07:05 PM
  2. trip computer/total distance computer STOPPED!
    By Juzzy21 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2007, 10:10 PM
  3. trip computer????
    By cdawg in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-04-2006, 07:30 AM
  4. VS Trip Computer
    By Andrew Richards in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2005, 01:00 PM
  5. VS trip computer
    By Berlina VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2005, 02:39 PM
