Hi just wondering what would cause both reverse light to not work, i have checked the fuse and its not the globes just wondering what else it coild be. thanks
reverse switch around gearstick playing up is probably the most likely culprit. give the stick a wiggle while its in reverse and see if the lights come on, i know on mine, i gotta push the stick right down in reverse for lights to work.
Same prob. here. I move bar toward neutral and reverse lights come on. Probably switch needs adj. or someth.
Thats more then likely your problem. I adjusted mine and now works fine.
Yeah I have the same prob. All i have to do is push the shifter right down when in reverse and they come on
Not too sure a mate of mine did it for me. will ask him and let you all know
where is the switch? under car? or is it under the plastic near ash tray? whats it look like?
I would like to know too. Mine does it. I'll put it into reverse and the lights don't work, but i pull it down a bit more and it clicks and the lights come on. I looked for the switch under the console but had no idea where it was or what it looked like either. Would be a good how-to thread if someone could do it cos it sounds like a common problem.
under plastic near ashtray, its a black one, its next to the base of the shifter. just look for wires near shifter and u should find it
fixed my reverse lights. i undid that black sensor switch thing. hit it forward and screwed it back down works everytime now.![]()
