Results 1 to 15 of 15
Thread: car spitting out black stuff
    VN V6
    Jun 2006
    Default car spitting out black stuff
    Hey, my car (vs series 1 v6) seems to be spitting out some black soot type stuff out the exhaust, is this a sign its running rich? as it does have a fuel consumption issue heres a pic, it really shoots out when you give it some revs
    Any ideas whats causing it?
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    running rich.. but that pretty bad.. check ur error codes..
    Check out my ride and rate it high plz
    VN V6
    Jun 2006
    its got a dump pipe on the end so it might be putting out more then usual, its not all from the one starting the patch closes is probaly two or three starts and revs worth
    and error codes are just bringing up 12 so nothing wrong there
    VRII Acclaim
    Jul 2005
    I normally get a couple of drops of water out of the exhaust on startup. I assume its just the cats turning CO2 into H2O, and a bit of standard black exhaust to make a slightly black water. Never that much though.
    J_D
    J_D is offline
    VN S1 and VS V8 Statesman
    Jul 2006
    Ipswich. QLD
    If its putting out excessive amounts of water/steam you might have a blown head gasket. I dont think you would get the soot falling in that pattern unless there was quite a bit of water involved.
    Im not a complete idiot, some parts are still on backorder!
    VN V6
    Jun 2006
    dont think its a blown head gasket however ill check it out, any other possible causes?
    Factory Blown VY S2 Calais
    Jun 2005
    Brisbane Bayside
    It's basically unburnt fuel - what's your consumption like ? Plenty of potential causes for it to run rich. For starters there is replace air filter, iac valve could use a clean and possibly clean throttle body, check o2 and flow sensors - these can be performing poorly yet fail to throw out a code, I can't think of anything else that you don't need a mechanic for ?
    VN V6
    Jun 2006
    yeah fuel consumption is pretty bad about 320km a tank
    by flow sensors you mean the maf sensor near the airbox?
    might take throttle body off and clean iac valve later and give the o2 sensors a check hopefully can find my problem, i can do most things mechanically its just learning exactly what these sensors do or better yet what happens when they aint working
    Jun 2005
    Brisbane Bayside
    Yeh - the maf sensor near the airbox, and the o2 sensors on the exhaust. The only wy to check them is to swap them out with known good ones though - so that ain't much help.
    Also the temp sensor can cause the 'choke' to stay on - that is, the 'puter enriches the fuel mix when the car is cold - when the car ain't cold but the 'puter thinks it is, you get too much fuel.
    VN V6
    Jun 2006
    ok went for drive before noticed temp guage was on cold the bottom line and drove for about 10kms and it went up to probaly just under half way too the half way mark so if its correct then i think its running cold which would indicate computer it running the fuel mix rich
    what sensor causes this, air temp sensor? or could it be thermostat? they also have a coolant sensor if im correct?
    VK wagon
    Aug 2006
    NZ
    if you park yor car out side then it also could be condensation/rain running in over nite. As kids we had to wash teachers cars for punishment and used to run the hose up the exhaust...makes an excellent water canon!! muffler wouldn't like it much though in hind sight...
    Jun 2005
    Brisbane Bayside
    Quote Originally Posted by silvr6 View Post
    There are two coolants sensors - one for the gauge, and one for the computer. The one for the computer is a simple on/off setup whereas the gauge one feeds back variable response - I'm not convinced that yours is running cold - 10k ain't enough to diagnose that, and it does sound like your thermostat is opening up, so I wouldn't sweat it.
    Check your air filter, clean up the throttle body and iac valve - spark plugs if they are due (even whip them out and clean them up) - possibly even fuel filter if it's time. Start with the basics, see if things improve b4 you get on to the technical stuff. Once you've done the basics, it may be worth taking it to a holden dealer and ask them to diagnose poor fuel economy (and describe the black soot) Chances are they'll tell you it need an injector clean and de-coking. 9/10 that these are cop outs and attempts to get a hold of your hard earned imho. They can test your maf sensor though, which is far too expensive to be replacing 'just in case',
    If one of your spark plugs is more fouled than the rest - maybe the injectors need cleaning - but who knows? I struggle along myself with not enough knowledge on these things, but too much self respect to be ripped off by the small number of mechanics out there that take you for a ride if you let them.
    VN V6
    Jun 2006
    thanks alot fletch, yeah still sticking with the basics like cleaning things up, going to check out spark plugs, air filter is fine may give it a change of oil and things which it maybe due for (have not had car a long time)
    Im currently running injector cleaner in it now and going to run another lot next fill up to help out abit, my last option will be to take it to holden and see if they can pin point my problem
    I was convinced it was running cold, cause the gauge barely moved from the bottom it was abit of spirited driving, i used to have a VN and within the same stretch of road it was running alot warmer and so does my vx SS, but it maybe a little fault the temp gauge that is
    Stewart1000's Avatar
    Stewart1000 is offline work done by ME
    VL twin turbo. VN5L. old jeep, shit mondeo.
    Sep 2005
    vic
    have you been parking the car in a different place than you used to?
    or driving it harder, with more revs?
    if you granny it for a long time the exhaust gasses have been travelling slowly through the exhaust system and that allows carbon to settle and collect in the mufflers and pipes, and then if you park the car outside, it gets condensation inside the system and out comes that wet sut when you give her a few revs.
    but yeah if thats the case it shouldn't do it all the time, it could be running very rich, i dont know how many oxy sensors the VN's have 1 or 2, maybe swap them with a mates car and see if the performance of the3 car changes, if it gets bettwe yours are stuffed, if it gets worse, your mates are stuffed, if its the same look further, like MAP sensor possibly.
    Good luck
    my web site
    stuff on the XF throttle body conversion, calais interior and lots of other junk!
  15. #15
    VN V6
    Jun 2006
    car is parked in doors normally try to give it a run atleast once a day, once she warms up it dont spit it out anymore so its possible its a build up but i got a feeling its still running rich because of the fuel consumption issue, almost finished cleaning up some sensors and throttle body so hopefully will sort this issue out
  1. Blue/black Dizzies And Stuff.
    By Kim in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 28-02-2012, 05:01 PM
  2. wtf is this black stuff?
    By VSSPak in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-12-2006, 09:42 PM
  3. Spitting oil out of exhaust
    By qwertsta in forum VL Holden Commodore (1986 - 1988)
    Last Post: 15-08-2006, 04:41 PM
  4. Spitting Coolant Help!!!
    By VScom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2006, 11:59 PM
  5. black stuff coming out my exhaust? oil?
    By maccona35 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 25-06-2006, 05:12 PM
