+ Reply to Thread
Results 1 to 4 of 4
Thread: Fitting double row timing chain
    Sep 2006
    Default Fitting double row timing chain
    I here u can fit a double row timing chain to a VR V6, but hear u have to remove the balance shaft and completely balance the bottom end. How do u completely balance the bottom end or know if it is? Thanks.
    Slow VR's Avatar
    Slow VR is offline Another White Crummodore Slow VR Executive
    VR Series II
    Apr 2006
    Cairns, Nth Qld
    Why bother, these engines seem to be able to do a trillion k's b4 needing a rebuild. Never heard of 1 snapping a timing chain, sure they will stretch, but just replace with single row. Not worth the hassle.
    Jumping Commodores is the right thing to do... Flex is a good thing.
    vx commodore
    Jan 2012
    toowoomba
    you can n they fit them they aint that much trouble so i figured out the hard way
    Jxw
    Jxw is offline Jxw Berlina
    a few commodores
    Feb 2011
    victoria
    only reason you'd install a double row was if you changed the cam, valve springs etc and put excessively more load on the cam.
    for standard applications the single row is fine, install a roller chain and get rid of the crappy link chain.
    you'd balance the bottom end the same as any engine (basic version)
    match all the pistons to the same weight.
    match all the conrods to the same weight.
    put special weights on the crank shaft to maintain the weight of the rod/piston assemblies (i forget it but there's an equation to work that out)
    then it'd be put on a special machine that spins it and the person doing it would grind bits off the counter weights (or drill and add a heavy metal if needed)
    not a cheap easy thing to do and unless you were putting the engine in a racing vehicle and intended to spin it past about 6500 rpm on a regular basis and i guess you'd be blue printing the engine, not worth it imho
+ Reply to Thread
  1. vs.. double row rollamaster timing chain
    By crzyvs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-01-2012, 10:54 PM
  2. HSV double-row timing chain vs timing gears
    By savage1987 in forum V8 Development and Modification
    Last Post: 04-10-2007, 11:04 PM
  3. timing chain
    By timboco in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2006, 05:09 PM
  4. timing chain
    By howareyou in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2005, 04:49 PM
  5. Timing Chain
    By vn_calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-09-2005, 01:10 PM
