Appears that ive got a bit of an oil leak around the valley cover, was going to pull it off and replace the gasket. Any 1 got any tips or tricks?
Looks like a straightforward job.
Jumping Commodores is the right thing to do... Flex is a good thing.
try tightning all the bolts first and see if that does the job before you pull it apart
Body by Holden, Soul by Brock
the Legend will live forever
Nah everything is tight, its coming off this weekend, ill also replace the rocker cover gaskets while im at it. Any 1 know of any other traps when this is done?
make sure you change the oil after cuz it can get some shit down there.
Not really any traps, just make sure you mark all hoses and electrical leads so you know exactly where to put them back when it comes time. Also, make sure you try and keep everything as clean as poissible.
If you're unsure about doing anything, go and buy a workshop manual before you start. $40 well spent and it could save you a few bucks down the track.
Are you noticing leaks from the front or rear... if oil is between the heads and manifold then it's most likely just the rocker covers leaking.
Disclaimer For The Reader ::
The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK or do not use the information at all.
I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
I am NOT a Mechanic. You have been warned.
Righto, yeah had oil leaks from the front n rear of the inlet manifold and also the rocker covers as well. So replaced the valley cover gaskets and also the rocker cover gaskets. Gave the inlet manifold a full on clean with like 3 tins of carb cleaner. Basically soaked it then gernied it.... Inside was just black as with carbon n crap. The TB was still clean from when i cleaned it a while ago. Changed the oil and filter this morn and topped up the coolant. No real dramas, gave the engine and bay a full degrease this arv.
