Results 1 to 6 of 6
Thread: towing
    VS
    Mar 2006
    Default towing
    hey fella's,
    ive just started towing behind my vs. its not much weight (jetski) but my cars seems to over heat way more than normal. i know vs's fan dont kick in till 3/4. my mine usally sits around 1/4 driving and if sitting at light for a while it will go up to 3/4 and the fan kicks in. when i tow it sits over 1/2 all the time. is this normal??
    cheers
    VS Acclaim S2
    Sep 2006
    my fan works the same as yours. The weather is getting warmer though and if your worried about it just turn on the air conditioning, it should turn on the fan. I dont tow though.
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by vswagoon View Post
    hey fella's,
    cheers
    Yeah sounds about normal, 1/2 is nothing to be worried about. If it was sitting constantly at 3/4 or more whilst driving, then it might be an issue. Sitting at the lights with it going up to 3/4 or a bit less is normal, mine does the same. Just make sure you are running the recommended GMH coolant, and at the correct rate, 50% concentrate and 50% water. If you decide to change the coolant, change the thermostat at the same time.
    I would be more concerned about overheating the auto, especially on series I VS, they didn't have the external cooler in front of the radiator, if you are looking at doing a bit of towing over summer, put one in, cheap insurance in my book.
    VS
    Mar 2006
    yeh i was getting a bit worried about it sitting between 1/2 3/4 when towing all the time.
    harves82 so do the series 2 hav them?
    Dec 2005
    Glen Waverley VIC
    Yeah series two VS have the external cooler, its a small rectangle shaped radiator just behind your rego plate. Series one VS do have a trans cooler, but it is part of the main radiator tanks, and is no where near as effective as an external mounted unit.
    If your car is fitted with a genuine GMH towing pack, especially the 1600 and 2100kg versions, then you should already have one of the external coolers... but if you are going to be doing any sort of towing over summer, I would highly recommend getting the auto fluid changed or flushed if need be, and making sure that the coolant is up to scratch too.
    sganro is offline i speak before i think
    yet another VS
    Aug 2005
    NQ
    i thought mine was running hot too, but seems like its normal. One less thing i have to worry about now
    There are no stupid questions, just stupid people
  1. SV6 and Towing a Car
    By 05 VZ SS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-01-2007, 11:19 PM
  2. towing
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2006, 10:42 AM
  3. Towing on P's.
    By =Calais v8= in forum General
    Last Post: 04-11-2005, 07:41 PM
  4. Towing with a vs ute
    By melbdan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 10:50 AM
  5. towing car. help...
    By LeojVS in forum General
    Last Post: 09-04-2005, 08:42 AM
