Hi ,
I have got VS-V6 the engine cut out for a second or two .I have check the wiring at the ECU ,DFI MODULE ,CRANK ANGLE SENSOR which is all ok,the ECU voltage at terminal D4 is 2.5 volts, is the ECU the problem.Has anyone had this type of problem please help :b:
Thank you
your crank angle sensor is knackered
time for a new 1! they cost bout $60 odd bucks n take about 20 mins to fit![]()
Our VS II had the same problem with the crank angle sensor a little while ago...
While I was driving into a carpark, the engine just stopped. It started again afterwards OK, but it was off the the mechanic for a check. He said they stuff up all the time on Commdores...
