How Do You Remove The Front Side Panels Of A Vs? Help!
r_i_d_a_h
'97 VS Commodore + '98 E36
Does Any-1 Know How To Remove The Screws That Hold The Front Panels On A Vs Commodore?. They Dont Seem To Budge! Help Me
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
More info please - just what do you mean by the 'front panels'?
r_i_d_a_h
i have damaged the front left side fender/panel (the panel where the side indicator sits/the panel which surrounds the front wheel) sorry im a bit bad with the names.
but any way i cant seem to get the screws, dat are hidden under the hood dat hold the panel down to budge..any tips on how to remove?
sixshooter
2x VS
If you cant undo them with a flat head screwdriver... buy yourself an impact wrench with screwdriver tips...it'll probably cost about $50. Also you need to remover the inner plastic guard which is held in place with screws and plastic plug screws to get to one of the bolts lower down...another is at the bottom of the guard attached it to the sill panel...and also there is another 2 holding the guard to the bumper !
r_i_d_a_h
fanx champ! ill try dat!
