Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: WHAT COOLANT IS BEST FOR MY ENGINE? help!
    '97 VS Commodore + '98 E36
    Apr 2005
    Question WHAT COOLANT IS BEST FOR MY ENGINE? help!
    what coolant is BEST for my 1997 VS commodore?
    when i purchased the car it came with no user's manual!
    so i have no idea on what type of recommended engine coolant shoud be used!
    so what is the recommended engine coolant for my engine and what are some quality branded name coolants i can purchase! (list full coolant names.)
    cheers guys!
    VS Exec Series II
    Mar 2005
    Quote Originally Posted by r_i_d_a_h View Post
    cheers guys!
    Just go with the genuine Holden coolant you can get from auto one and other auto stores. It comes premixed. Might be an idea to flush your old system though if you are unsure what is currently in there. I believe even using the same colour coolant can get you in trouble.
    Clacks
    VU Storm
    Jan 2006
    go get the nulon concentrate for commodores, falcons and toyota's, its good stuff Im running it in mine now.
    How to be a good Australian Citizen: Drive a Camry, Become another number in the system, Dob in all other numbers for un-numberlike behavior (no matter how slight), Base all your opinions solely on the information provided by T.T. and A.C.A., Believe everything our gracious Government Tells you to.
    TheForgotten's Avatar
    TheForgotten is offline only human......
    VR EXEC
    Dec 2005
    quarantine
    I only use holden brand or tectaloy. but remember with holden brand coolant you need to use pellets aswell to lube the pump seal. they only cost about $5 from holden. tectaloy doesn't need them, as the lube is mixed in
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    MY08 Subaru Liberty GT-B & VS Exec
    Dec 2005
    Glen Waverley VIC
    Quote Originally Posted by Clacker View Post
    Clacks
    The genuine Holden coolant is a concentrate, and thats the one you need. Just pick it up from a Holden dealer, its about $39 for the 5 litre bottle, and about $12 or so for the 1 litre. Definately a good idea to flush the block and radiator completely before adding in the new coolant. Also, NEVER mix coolants, the chemical properties are different for each one, and can have a bad effect on the cooling system, sometimes even increasing corrosion.
    For the V6 you will need 6 litres of the concentrate, and 6 litres of clean water. The capacity of the system in the VS V6 is 12 litres, which includes radiator, block, hoses etc and the reserve tank.
    The best way I have found of getting all the concentrate in is to make sure your heater is set to full heat, remove the top radiator hose and thermostat, flush radiator, and remove bottom hose, then flush the block by putting the hose into the thermostat opening, and wait until clean water is coming from the bottom radiator hose. Then hook up the bottom radiator hose, pour the entire 5 litre concentrate into the radiator, then put the thermostat back in, bolt it all back together, put another 750mL concentrate into the reserve tank, then just fill the rest of the system with clean water, that way you have the correct 50/50 mix of coolant concentrate and water.
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Quote Originally Posted by TheForgotten View Post
    the pills dont actually lube anything, they are made from crushed walnut shells & the bits float around in the coolant & keep the scale off the rear of the waterpump seal.
    just some useless trivia.lol
    Rob
    Apr 2005
    i hear its a good idea to replace the thermostat? how much will that cost? lol AND (sounds like a silly question) where is the thermostat of wuheva located in the engine?
    btw. are there any other components that needs replacing while im on the coolant drainin job?
    VS S1 Executive V6
    Aug 2005
    Maroochydore
    theres a few good threads on this topic - heres a good one
    changing thermostat
    Something I've Been Getting Into Lately....
    Get Paid To Surf The Internet!
    Program About To Be Released So I Jumped Aboard...
    http://www.agloco.com/r/BBDB3431
    2x VS
    Jul 2005
    Quote Originally Posted by Stupa View Post
    I second that... get the 5L Long Life 100% concentrate.... flush your cooling system then use it all in you radiator and top the rest up with distilled water.
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    Quote Originally Posted by Doctor Bob View Post
    Rob
    Steady on there Doctor Bob, they ain't made from just any old walnut shells but extra fine hand-picked ones. My source says they are used to stop small leaks experienced during assembly. Back in the 70's, Jaguar used Barrs pellets in all Jaguars and they were part of the regular service items - trouble was that the pellets (reputably made from pepper) settled to the bottom of the radiator core and slowly but surely blocked the flow of water thru the engine. Cost the company a lot in $$$ and reputation. More useless trivia.
  1. Change the engine coolant.(vn,vp,vr?,vs?)
    By ViperVp in forum Holden Commodore How-To's
    Last Post: 09-08-2008, 08:51 PM
  2. leak coolant and oil from Engine?
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-01-2007, 04:04 PM
  3. Leaking engine coolant
    By 2000V8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-12-2005, 03:04 PM
  4. Flushing Engine Coolant?
    By KILLERVS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-10-2005, 04:47 PM
  5. Weird Engine Coolant
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-04-2004, 07:12 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97
