Results 1 to 12 of 12
Thread: Swapping left to right????
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    Default Swapping left to right????
    Hi,
    As most of you know that commies with IRS get really bad tire wear on the inside.
    So I wanna know that is it ok to swap the rear (Directional) tires to the opposite sides cos the front ones already have wear on them. (So cannot use the front ones)
    I have 17"s on ROH mags but the tire states that it rotate only one way I assume that it would be dangerous or unsafe (No Grip) to have the tire rotating the opposite way after the swap??
    (I know a camber kit will correct this but my funds are short due to some engine problem which must be corrected first, so please leave out camber kit suggestions)
    The car is not lowered (Yet!)
    Thanks in advance guys!!!!
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    grip is effected slightly but not much the only thing that happens is that the tyres tend to wear more quickly because the rubber is moving in the opposite direction than its supposed to, also you'll find that the tread gets bumpy and uneven which will cause vibration problems
    We got rep back, yaaay!
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    you can get your tyres swapped onto the opposite rims and keep the tread facing the right way. costs about $40-50 for a swap and balance on the rear
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    You will need to get the tyres swapped on the rims or the worn part will still be on the inside.
    ephect's Avatar
    ephect is online now Donating Member
    VS Acclaim V6
    Jul 2006
    also depending on the current wear on the inner tread, if its below legal, its easier for the coppers to get u for defect, once swapped.
    VS Acclaim V6
    May 2005
    You guys reckon that any tire place will swap my tires to the opposite rims even tho there is a bit of wear on the tires?? The tires are in very good cond't only inner is worn a bit but the outer side is like 85% tread on them. I just don't want them forcing me to buy a new tire. As I said before my funds are short due to the engine work I'm doing.(Fixing problms) so new tires is out of option atm.
    VP Executive 5.0L IRS ABS
    Oct 2006
    Default Yeah no worries
    I've had the tyres spun 180 degrees on the rims at a couple of tyre places before, cost me $20 for both and they rebalanced them. I had it done for a similar reason, I think the outside had worn more than the inside on the front tyres on my LC Torana. But I left the wheels on the front of the car, and had the shop do a wheel alignment at the same time. The car always pulled to the left and I thought they had stuffed up the alignment, but when I finally put brand new tyres on the front, the car drove perfectly straight so I can only think the unevenly worn tyres made the steering pull. So maybe your car will feel a bit different to drive. Nothing a small burnout might fix though If you have them spun 180 degrees on the rim, and then swap the sides the rims are on, the tyres should be turning the right direction again right???
    VS Acclaim V6
    May 2005
    Quote Originally Posted by stockyvs View Post
    Yeah it would turn in the right direction.... So I think I'm gonna get them spun 180 degrees like you did and see how it goes. Hope I could do this under $50.
    Looks like my rear main seal on the Ecotec needs replacing so won't be able to afford new tires for a long while yet.
    Oct 2006
    It should be $20-30 if you just take the wheels in, off the car. If someone said $50 to me I would want gold plated wheel weights or something! How bad is the main seal? I don't know of a Holden that doesn't leak oil! If your car hasn't blown the trans yet (it's an auto isn't it?) you could wait until it does (they seem to go around the 150,000KM mark), and make sure you get them to replace the main seal then. The only reason it costs so much is the labour pulling out the box to do it - I don't think the seal costs more than $20, I paid $10 for a front seal.
    VS Acclaim V6
    May 2005
    My car has done about 219,000k's now and is in for a service soon. The tranny (Auto) is going really good and have no probs with it but it just recently the engine has very rough idle and when I checked the rear where the tranny bolts on to the engine there is a wet look all over the tranny and I assume the seal would need replacing.
    How much will it cost to replace the main seal including labor??
    Oct 2006
    Not sure about the rough idle, wait until after the service I 'spose and see if that fixes the rough idle. Not sure on the main seal, I never pay people to do that sort of thing but then I never fix them any more either!!! Maybe call a couple of auto trans shops for quotes on the main seal as well - every mechanic I know carries on about how hard it is but all you have to do is pull the box out - which trans shops do all day everyday!!! So it would probably be quicker = less labour cost. It would take no more than 2-3 hours labour to do it with a hoist + the seal cost.
    VS Acclaim V6
    May 2005
    Thanks a lot for your input!! Yeah I decided to take your advice and call tranny shops around my area instead of my mechanic.(I think his is very busy atm with all these old cars breaking down in summer!!)
    As for the rough idle, I wait and see how it goes after the service but I doubt it will fix it cos only recently I replaced the sparks and the leads. I'm suspecting its the coilpacks or the engine control unit and Vacum lines.
  1. swapping clusters
    By MiSs MeOw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-04-2007, 04:11 PM
  2. Swapping cam in VR VS V6 ?
    By sixshooter in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-04-2006, 02:36 PM
  3. swapping motors need help
    By holden man77 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-07-2005, 02:47 PM
  4. Swapping Struts.
    By SV-3800 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2005, 04:42 AM
  5. Swapping clusters
    By furrhead in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-06-2005, 11:16 PM
