thought it would be ok cause the VR still uses the MAP tune but i could be wrong. the V8 TB does bolt straight up and is 65mm Vs 60mm standard or you could get a 70mm bored job from the net. maybe have a look in the "how to" section and look for foamy's thread on how to make sure the TB opens 100%, then clean up your standard TB by grinding out the lip nearthe butterfly and you could also knife edge the butterfly and if you get really enthusiastic you could also pull the TB apart and slim down the butterfly shaft. the larger TB doesn't give much in the way of performance untill you get into the bigger mods like cams and porting the heads etc whe nthe xtra flow potential is really needed. everylittle bit helps though in the bigger scheme of things.
