+ Reply to Thread
Results 1 to 5 of 5
Thread: vr calais check light on trans slipping under revs
    vr calais
    Jan 2007
    Question vr calais check light on trans slipping under revs
    I have a 94 calais when your on the open road the check light comes on, when I plant the petal to the floor, you can feel the trans slip alittle, the trans seems over wise find, and around town the check light stays off.
    Can anyone help with advice here please
    92 VP Calais International - RIP VR Turbo
    Jul 2005
    Echuca
    VRII Acclaim
    Jul 2005
    As tysons_2001 says, check error codes. If your engine warning light is coming on, the computer will register an error code. Pull the code and you should have a good idea of your problem.
    hako is offline Donating Member hako Senator hako Senator hako Senator
    VS11 BT1 V6
    Aug 2004
    Toowoomba SE QLD
    And I'd do a fluid level check on the auto trans - if its low it will slip and create error codes.
    vr calais
    Jan 2007
    Thumbs up
    Thank you for the advice guys
+ Reply to Thread
  1. check engine light comes on????
    By Brucefromruse in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2007, 04:53 PM
  2. Auto Trans Slipping? (VS)
    By nado69 in forum General
    Last Post: 26-09-2007, 11:41 AM
  3. calais revs
    By dsnutz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-05-2006, 02:14 PM
  4. VS Calais revs drop at idling speed
    By vsuterus in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-12-2005, 01:22 PM
  5. Check Engine Light
    By richie83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2004, 09:36 PM
