Just wondering if I can lower mr Vr Acclaim by just buying the springs or is it a must to get the shocks done too? Car is at starndard height now and looking at getting superlows? Any ideas thanks
im pretty sure if ur getting super lows u need new shockies as well not 100% sure but
also depending on the rims getting the guards rolled wouldnt hurt either again not 100% sure if needed but hope this helps
Thanks any other opinions???
yep. superlows will need new shocks preferably shortened. if you went lows then you wouldnt. and you will need a panhard rod cause the wheels will lean causing uneven wear on tyres. hope helps
