Hey people,
I have a VR 5ltr BT1 and it wouldnt start yesterday so i got my mate whos an auto sparky to look at it and he reckons its the fuel pump because you cant hear it priming with the ignition on and no fuel is coming out on the engine side, and also the spark at the plugs is normal. I tried the code thing and it came up with 12( system ok) so i was just wondering if it could be anything else or will i have to drop the tank and replace the pump?
cheers
simple test
crank the engine over, if it doesnt start look at either the following..
the fuel pump (hearing it prime, cant miss it if its a 5 litre, they are noisy as buggery), and or the dizzy, check its on properly
sounds to me like it is the fuel pump though
just check your getting voltage to it, just to make sure its not like a fuse or something small before u go fishing the pump out the juice tank
