Results 1 to 6 of 6
Thread: between gears
    VT wagon S2
    Nov 2005
    Default between gears
    g'day all ive just noticed that when im in reverse and i change into drive after coming to a stop, it sort of shudders a bit, im just wondering what it is thats making it do that?
    The Darkness's Avatar
    The Darkness is offline Junk Yard Dog
    Charged VT V6 A4
    Nov 2006
    Ipswich
    VT wagon S2
    Nov 2005
    Charged VT V6 A4
    Nov 2006
    Ipswich
    sounds like a worn trans. maybe give it a service. the older the trans gets, it takes longer for it to change gears. in a new trans it will change on about 0.5 sec. in an older one it could take up to 2.5 seconds to engage. if you accellerate before it has gone into gear when it does it will jolt badly. hope this helps
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    A service may fix it. Sounds like the shift solenoid is sticking and the pressure build up is making the pump work a bit harder resulting in a slight drop in revs.
    VT wagon S2
    Nov 2005
    thanks boys
  1. 3:7 or 3:9 GEARS!
    By VZHSV in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-09-2007, 03:08 PM
  2. gears
    By caminsa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2007, 04:22 AM
  3. 3.46:1 gears
    By chappy in forum General Discussion
    Last Post: 19-02-2007, 05:02 PM
  4. FS: 3.45 gears VN-VS
    By simc in forum Parts And Other Items For Sale
    Last Post: 04-04-2006, 08:44 AM
