Diagnostic terminal on VR SS
UN4TOLDVRSS
un4toldvrss
VR SS
Hey Guys,
new to the forum and was just wondering where i can find the diagnostic terminal under the dash of a VR SS commodore...first i have owned and obviously have no manual as yet...Cheers:thumbsup:
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
where the fuse panel cover is under the steering column approximately in the centre along the bottom is the connector
UN4TOLDVRSS
un4toldvrss
VR SS
Want to check timing and it's the first time dealing with a chip controlled commie.....how do i ground the diagnostic terminal????
JcB
Pukekohe - New Zealand
VS Calais Series II
If you mean ground (as in connect the ground to ...) well the diagram is pretty good. LOL :)
JcB
VS Calais Series II
Ooops! It's not so clear on the VR connector. Do you want to ground pins 5 and 6 for a diagnostics on your car.
UN4TOLDVRSS
un4toldvrss
VR SS
Lol....says to ground the terminal JcB...i take it that means to "earth" before applying the timing light....cheers again
