Results 1 to 12 of 12
Thread: Water on Drivers Side Floor.
    Jul 2006
    Default Water on Drivers Side Floor.
    Guys,
    I have a VR V8 Statesman.....Using Air Conditioning and driving as normal, noticed that there is water building up on the floor where brake/accelerator pedals are.
    Assuming this is an issue with the A/C or something else.
    If it is A/C, a little worried it is remove the dash time!!
    Jamie
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    The drain is blocked . Dont know were it is on the VR but look for the 2 little drains get some wire into it from under the car (Jack stands) Around Tranny
    and 3 Dangerous non ABS VN's
    VS S1 Executive V6
    Aug 2005
    Maroochydore
    Something I've Been Getting Into Lately....
    Get Paid To Surf The Internet!
    Program About To Be Released So I Jumped Aboard...
    http://www.agloco.com/r/BBDB3431
    VRII Acclaim
    Jul 2005
    Yep, near the transmission, under the car. I normally go in the passenger side. Just need to jack the left front side, normally enough for me to get under and find the drain. You should always use a cable tie, wire can damage the tube. You may have a wire insert that you will have to remove to unblock it, although mine never existed. Its in a bit of an awkward position, but once you find it, it shouldnt take too long to clear. The picture in the link (thanks to hako) is a real help, VR only has one though. Word of warning, there will be a lot of water coming out, so be ready to retreat in a moments notice.
    Make sure you do it really soon though. Mine leaked recently, about maybe 3 or so times before I got around to fixing it. There wasnt much water, and it dried up so I wasnt too worried about it. A few weeks later was doing some work around the drivers side, and lifted the carpet to run some wiring. The underlay was still very moist. I left the underlay lifted up, so that it would dry. After 2 days, it was still moist, and I used a hot air gun to dry the last bit. It probably wouldnt go mouldy, but it wasnt a very nice smell.
    Jul 2006
    Default Air Conditioning Woes.
    Guys,
    Thanks again for the replies....
    Will attempt it when it gets daylight outside!
    Will let you know...
    Thanks
    Jamie
    Jul 2006
    Hi again,
    Looked underneath yesterday, for the life of me could not find it.
    Will try again tonight to see if I can locate it.
    I am guessing it is on the passenger side, undernearth the car, near the top of the transmission?
    Thanks
    Jamie
    VRII Acclaim
    Jul 2005
    Keep looking mate, sounds like youre in the right spot. I would try and describe its location some more, but could get you more confused.
    93 VR Commodore Manual
    Feb 2007
    Queensland, Sunshine Coast, Noosa
    My problem is similar.
    My car was in the backyard for a while, it had been pouring down all day, opened up the car (None of the windows were down) and there was a small puddle on the passenger side floor, anyone know were it could be coming from?
    VRII Acclaim
    Jul 2005
    Your problem is going to be different BlackCougar. I would be going for a leak somewhere. I would get a mate to hose the car all around the bottom of windscreen area while you look around inside for leaks. Maybe around passenger door area too.
    Feb 2007
    Cheers man, will have a look.
    Most of the old commodores leak water into the boot when you lift the boot up do they? I don't want to put a sound system in there to open my boot after it raining and have water go all over it, what can I do to stop this as well?
    Jul 2006
    Default Water on Drivers Side.
    Hi again,
    Finally found the tube on top of the transmission tunnel.
    Used a Looooong bag tie and pushed it up and in and out....
    Nothing came out.....Been running all day today, seems like it is fixed!
    I was thinking something would come out, but it might have been something just holding it in....
    Oh well......
    Thanks everyone for your help!!!
    VRII Acclaim
    Jul 2005
    Quote Originally Posted by BlackCougar View Post
    Water can get in the boot, but you will normally find it gets under the spare wheel. You can put your sound system/gear in there, shouldnt be a problem.
    If you do have this problem, have a search around on here. You will find there are a few spots that can leak, just got to find the one on your car. Common one is through the passenger rear quarter window. There is a full how-to on here somewhere on repairing it.
  1. water getting under drivers side carpet???
    By clarkey3 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2006, 11:16 PM
  2. Air Con water on drivers foot
    By snog in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 13-02-2006, 06:08 PM
  3. water on the floor
    By VRFURY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 06-08-2005, 10:19 AM
  4. Water Leak at Drivers Door
    By Naccas in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 26-08-2004, 01:34 PM
  5. Water coming out of floor vents
    By Phiness1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-07-2004, 08:57 PM
