Results 1 to 9 of 9
Thread: car wont move
    shammee Guest
    Default car wont move
    ok where to begin. My VS was jumping into gear, thinking it was low transmission oil so I topped it up and still continued to do the same thing. THEN it got to the point where it wouldnt move by accelerating...3000rpms and it started to slowly move...Now the gear box has been recond and it is still doing the same thing. The shaft isnt turning either. We jacked up the back put it in reverse and one wheel turned but not the other. WHERE DO I GO FROM HERE?? Has it got something wrong with my diff? If not then what is it??PLEASE HELP!!!
    DJ Majah's Avatar
    DJ Majah is offline Electro doof doof styleé
    VSII cruiser
    Jan 2004
    Brisbane - Ipswich
    Only one wheel is supposed to turn unless you have a limited slip diff, but lets assume you dont.
    Does the car drive OK in drive, or doesnt it go anywhere at all?
    Queensland - The Cruising State
    shammee Guest
    sorry, it aint going anywhere now. Im thinking it is to do with the diff..the gearbox and converter have both been looked at and recond, but Im not very cluey about these sort of things..wot do you think?
    cheers
    2_SeeK_U's Avatar
    2_SeeK_U is offline Wheels on the bus go round and round...
    1997 VS Commodore II
    Oct 2003
    Wollongong
    Could be a power issue. When l had minimal power in my commy, it wouldn't change from first (auto) and it would hardly go anywhere.
    I'm not saying its not the diff, but l would lean towards a transmission problem....
    ::```cCcc`````````````````````````````::
    DJ Majah's Avatar
    VSII cruiser
    Jan 2004
    Brisbane - Ipswich
    What you can do to test the diff is to jack it up (both rear wheels), stick it in N and spin the wheels by hand. Try one side in a forwards motion, the other wheel should start spinning backwards and the shaft heading into the trans should spin as well.
    shammee Guest
    update on wots doin...replaced the diff, still nothing. You cant hear any change when you change the gears. Is it something to do with the gearbox still?? I'll come back when i get some more details on wots going on....
    VE Berlina International II
    Nov 2003
    Sounds like the bands in the gear box are stretched, sounds like the gear box might need a service.
    Does it move when its warm?
    Thats all right, thats ok, I drive a commodore anyway!!!!
    shammee Guest
    Thumbs up
    Its driving!!!YEP everything is sweet now. Rang the guy who recond the gearbox and he asked how much trans oil we had put in so we need another 2 litres. I knew it would be something small and silly. Well Iam happy now and I reckon I did ok for a female!!!
    Thanks to the others who offered there imput on the whole thing too!!!
    cheers
    Nov 2003
    hmm wouldnt have been good for it.....id get the gearbox checked out not definatly just to make sure it wasnt damaged
  1. car just wont move
    By dave.b in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-02-2006, 02:58 PM
  2. H/U move
    By raZel in forum Car Audio
    Last Post: 14-09-2005, 10:41 PM
  3. vl wont move
    By stock_vl in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-08-2005, 12:38 PM
  4. Own a VX looking to move to VY
    By Thirls in forum VY Holden Commodore (2002 - 2004)
    Last Post: 22-03-2005, 04:46 PM
  5. good move?
    By VksupaNoob in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 20-02-2005, 06:11 PM
