+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 30
Thread: engine check light came on then went off??
    vs calais eco
    Sep 2006
    Disney land!
    Default engine check light came on then went off??
    ok the other day the missus was picking the kids up from school and noticed the check engine warning light was on! the car seemed to be running fine no missfires or anything and then when the car was stopped to pick my son up after it was restarted the engine light was off! any ideas?? the car is a v6 vs calais!
    The Darkness's Avatar
    The Darkness is offline Junk Yard Dog The Darkness Executive
    Charged VT V6 A4
    Nov 2006
    Ipswich
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is offline Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Go around all the sensor plugs and make sure they are secure. Could be that the O2 sensors are starting to go. Check to see if an error code was logged.
    vs calais eco
    Sep 2006
    Disney land!
    Quote Originally Posted by 4BDN_VR View Post
    yeh i get this sometimes as well
    im thinking either sensor on the way out or faulty ignition coil could also be just old wireing to! dont think it would be coil pack as no rough idle??
    vs calais eco
    Sep 2006
    Disney land!
    Quote Originally Posted by Not_An_Abba_Fan View Post
    yeah faulty o2 sensor was the first thing to spring to mind!
    TheForgotten's Avatar
    TheForgotten is offline only human...... TheForgotten Calais
    VR EXEC
    Dec 2005
    quarantine
    check the codes. when the light comes on then goes off it means a code has been logged
    Quote Originally Posted by MY-42-VT
    if they didn't have that thing between there legs we'd laugh and throw rocks at them
    WTB VR/VS FACTORY HEADUNIT BRACKETS PM ME
    Charged VT V6 A4
    Nov 2006
    Ipswich
    VRII Acclaim
    Jul 2005
    As TheForgotten says, check error codes. No point having stabs in the dark about what it could be - could be hundreds of things. There is a how-to that describes the process.
    vs calais eco
    Sep 2006
    Disney land!
    no worries fellas will check the codes see whats loged cheers for the help!
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ VN_Luke W427 VN_Luke W427 VN_Luke W427
    VT, RB30EST VN
    Mar 2005
    at least the missus correctly identified it as an engine light....
    every time mine goes on she [the missus] says the "oil light came on" which almost always gives me heart attack.
    VX Series 2
    Dec 2008
    Canterbury Area, Sydney
    Oxy sensor, champ. They commonly fail and give an engine warning light here and there.
    If its not working, you're not hitting it hard enough.
    greenacc's Avatar
    greenacc is offline Searching for the billion greenacc Calais
    VE Berlina
    Tetris Champion! Office Blocks Champion!
    Jul 2008
    Jackson, i notice you're a newB so I'll just point out that this thread is nearly 2 years old .. not sure where you dug it from but its probably been fixed by now.
    Maybe CXCXCXCXCV can come back and tell us what it was ?
    VT COMMODORE
    Dec 2008
    Mine did the same thing. Buy 3 cans (about $10ea) of throttle cleaner and spray out your throttle etc. Clean up your egr valve and injectors and if you can get to the O2 sensors, carefully take them out and clean them. You will be suprised how much built-up carbon pours out which is soaking up your oxygen and throwing off your sensors. You car will run smoother and use less fuel.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Damn that carbon soaking up all my oxygen.....
    http://www.facebook.com/?ref=home#!/...21292461287296
  15. #15
    vs clubsport
    Aug 2008
  16. #16
    DannyboyDS is offline Just hand me the pliers. DannyboyDS Monaro DannyboyDS Monaro
    VS Berlina
    Feb 2007
    wouldnt suprise me if CXCX had faulty oxy sensors given his current fuel usage problems, however Im sure he has since replaced them and earthed them correctly.
    I wonder if CX will check in to let us know what went so wrong so long ago?
    Just thought id add my two cents but thread digging isn't always bad, sometimes a thread will cover some very usefull information or some of the info will be incomplete and someone will fill in the gaps or add a little extra its refreshing in a way, dont some of you long time members get sick of answering the same question from scratch? isnt it easier when someone uses information already available to discuss there new problem?
  17. #17
    VS Series II
    Nov 2007
    Newcastle
    Ive had this problem for ages. Any updates as to whether or not it was the o2 sensor?
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Just do a code check and find out. In the How To section.
  19. #19
    VS Series II
    Nov 2007
    Newcastle
  20. #20
    V8 VZ Calais (on P's)
    May 2009
    Golden Grove/Spring Hill- Adelaide
    somtimes couldnt these things be somthing even more simple like a faulty globe or somthing ( only said this cause no-one else has and from i kno it is possible?)
  21. #21
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Code 76 points directly at the O2 sensor. Cut the purple wire on the RH sensor, (on the loom side of the plug) and reset the PCM, take it for a drive and check the codes again. Cutting the wire won't really hurt anything. It was a Holden fix back in the VS days anyway.
  22. #22
    VS Series II
    Nov 2007
    Newcastle
    If I cut the wire on the loom side, and get a new sensor, it will still be cut, shouldnt I cut it on the sensor side?
    If its not going to make matter worse, I will give it a chop.
  23. #23
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Which ever side you cut it, it doesn't matter, but the problem is in the circuit, not the sensor. If you get a new sensor and the loom side isn't cut, the problem will still be there.
  24. #24
    Vr Commodore V6
    Apr 2006
    Default Personalised Comodore number plates Victoria
    Hi all. Just wondering if you guys can give me an estimate of what I should ask for these plates, as a guy down the street keeps pestering me for them.
    http://s437.photobucket.com/albums/q...nt=Cmodore.jpg
  25. #25
    VS Series II
    Nov 2007
    Newcastle
    double what you paid? lol.. i have no idea - dont know what they are worth
+ Reply to Thread
  1. Engine Check Light
    By impressive in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-07-2009, 09:16 PM
  2. Engine Check Light
    By pro_gmh in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2006, 01:51 AM
  3. Check engine light
    By Seeker in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-02-2005, 08:48 PM
  4. Check Engine Light
    By richie83 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2004, 09:36 PM
  5. Engine Check Light
    By jaydee in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2004, 04:34 PM
